Unofficial "NQD" Tear into Jetboat Thread
#2851
RE: Unofficial
I found [link=http://www.ebay.com/itm/LEOPARD-2040-13T-KV4450-2-Poles-Brushless-Motor-IM012-/130644403327?pt=Radio_Control_Parts_Accessories&hash=item1e6b03647f]this motor[/link] on Ebay and it looks to be a more appropriate motor for use with a 2S lipo. It is 4450kv and should balance the top end speed, eliminating that dead space in the top 25% of throttle movement. Be sure to use it with a water jacket such as [link=http://www.ebay.com/itm/Water-Cooling-Jacket-for-20mm-RC-Boat-Plane-Motors-New-/260832115659?pt=Radio_Control_Parts_Accessories&hash=item3cbace3bcb]this one.[/link].
#2852
RE: Unofficial
ORIGINAL: sundogz
I'm not sure how, but receivers and servos that are enclosed in balloons will sure as rain acquire some moisture. This has been told time and again. The best way to waterproof servos and receivers is Conformal Coating or spray Liquid Electrical Tape. I use the latter and have had no problems. I also am a fan of higher voltage/lower amperage running and use 3S batteries in this boat. I'm currently running a 3000kv outrunner with no water cooling. Quite fast and no appreciable heat buildup after long runs.
I've been doing this for years without a single problem...
#2853
RE: Unofficial
half way through my second conversion, an drilling the coupling for the new motor ive messed it up.
anyone know anywhere to get a coupling for a 4mm shaft motor? all the ones ive seen so far are to big to fit into the drive.
#2854
RE: Unofficial
ORIGINAL: sundogz
I found [link=http://www.ebay.com/itm/LEOPARD-2040-13T-KV4450-2-Poles-Brushless-Motor-IM012-/130644403327?pt=Radio_Control_Parts_Accessories&ha sh=item1e6b03647f]this motor[/link] on Ebay and it looks to be a more appropriate motor for use with a 2S lipo. It is 4450kv and should balance the top end speed, eliminating that dead space in the top 25% of throttle movement. Be sure to use it with a water jacket such as [link=http://www.ebay.com/itm/Water-Cooling-Jacket-for-20mm-RC-Boat-Plane-Motors-New-/260832115659?pt=Radio_Control_Parts_Accessories&ha sh=item3cbace3bcb]this one.[/link].
RE: Unofficial
ORIGINAL: spektrumFlux
may I know does the Leopard Motor fit into stock motor mounting without the need for modification?
Thank
Thank
#2856
RE: Unofficial
ORIGINAL: sundogz
Yes, it should fit just like it is.
Thank
Thank
then I will order this Loepard + water jacket combo for better run performance instead of the 2040L 4800kv motor.
#2857
RE: Unofficial
great thanks. :-)
Btw is there a limit on the maximum 2S Lipo C usage?
i.e. will there be issue using a 2S 40~80C Lipo?
ORIGINAL: sundogz
Thank
Thank
#2858
RE: Unofficial
No, the Lipo c rating is an indication on how fast that battery can discharge, I.e. how much juice you can feed the motor, more is better
#2859
RE: Unofficial
ORIGINAL: seehuusen
#2860
RE: Unofficial
another thing to consider with C ratings...
the C rating is referenced from the capacity of the battery.
so a 2000mah 20C battery can handle 40000mah load (or 40A constant)
while a 2500mah 20C battery will handle 50000mah load (or 50A constant)
so the same C rating will vary depending on the capacity of the battery.
some manufacturers are better at claiming genuine C rating than others.
the higher C rating simply means that for a given load, the battery voltage will not
sag under that load.
Jason.
Jason.
#2861
RE: Unofficial
ORIGINAL: Ratrunner
Jason.
Jason.
#2862
RE: Unofficial
http://www.commonsenserc.com/page.ph...explained.html
here's a link that explains it.
the c rating is dependant on the capacity of the pack.
that's what the "C" stands for Capacity.
so for example, when a battery says it can be charged at 1C it means that you can charge at the rate of the capacity of the pack.
ie, 1C on a 5000 mah pack, means a charge rate of 5 amps. 1C on an 8000 mah pack means an 8 amp charge rate.
the same logic applies to discharge rates.
Jason.
Jason.
#2864
My Feedback: (81)
VA
RE: Unofficial
Hey guys, could someone post a link of the water fitting that you are using on the jet rudder? Isn't it called a statter or something?
I was looking at this, but I think it needs to be plastic.
http://www.offshoreelectrics.com/pro...od=ros-SPD-102
#2865
AZ
RE: Unofficial
Hey Guys, I happended to be surfing around when I bumped into this Ratrunner's post. I couldn't let this one go by without giving a warning.
NEVER charge Lipos at an amp rate greater than that recommended by the battery manufacturer!!. That's how fires are started.
"C" rating refers to the maximum discharge rate only, not the charge rate.
There is some confusion here about MAh and C ratings and what they are. Here's how it was explained to me once:
If you think of a battery as a fuel tank, the MAh rating is the capacity of electricity, or "fuel" it can hold. MAh stands for Milliamp hours, or how much power a battery can discharge over time. For example in an hour, a fully charged 2500 MAh battery will give up 2500 milliamps (or 2.5 amps), its entire charge. The same battery can discharge 5000 milliamps (5.0 amps) in 1/2 hour. (By the way, you should never discharge a Lipo more that 70%-80% of its capacity or you'll ruin the battery in no time.)
The C rating refers to how much of a battery's total capacity it can discharge at any one time. A 1C rated Lipo can only supply a maximum of 2500 milliamps (2.5A) while a battery rated at 10C can give up 25 amps. A 30C battery could give up a whopping 75 amps. Remember though, you've only got 2500 MAh in the battery. At 30C the entire battery's charge would be gone in 2 minutes. Since you should never completely discharge a Lipo, a motor drawing a full 75 amps should only be run for about a minute.
This is why you need to consider a motor's amp rathing when you match it with a battery. If your motor has a 25 amp rating, then your battery better be able to supply that much current - or your battery will be destroyed - I've puffed Lipos in the past trying to get more speed out of FE boats.
#2867
RE: Unofficial
thanks for taking the time to explain that John, you're bang on mate
C rating is only for discharge, but most batteries will also have a charge rate written somewhere.
If you don't have a charge rate, you should go with a 1C charge rate, so if you have a 3000mah battery, you can charge that at 3amps
My Nanotech batteries allows a 5C charge rate, which my charger can't even do!!! (5C x 2.2A = 11amps)
All other batteries I own are charged at 1C (although I have safely charged multiple times at 1.1C with no drama)
Cheers
Martin
#2868
My Feedback: (81)
VA
RE: Unofficial
ORIGINAL: Wheelnut
#2869
RE: Unofficial
ORIGINAL: seehuusen
Cheers
Martin
some of us have chargers that can handle up to 20A charge rates, so we can charge at those higher levels.
as has been stated here, always follow the manufacturers recommended MAX C for charge rates.
you can always charge slower, but NEVER higher.
Jason.
#2870
RE: Unofficial
thanks folks for all the guidance. :-)
so always get the highest C Lipo battery where possible.
btw any suggested torque (kg.cm) servo to go with the NQD?
I suppose Standard size servo could still fit into the tiny compartment?
#2871
RE: Unofficial
ORIGINAL: Wheelnut
There are definitely photos of this in this thread
#2872
RE: Unofficial
ORIGINAL: Ratrunner
that's spot on also.
Jason.
Jason.
#2873
RE: Unofficial
it's about BOTH maximum charge and discharge rates as well as related to the capacity of the pack.
the maximum C rate for a pack will be written on it for both discharge and charge.
these will be 2 DIFFERENT multiples of the CAPACITY of the pack.
an example of one of my 3S nanotech packs is as follows.
it's a 3S 11.1V 4400 mah pack.
it's rated at 40C constant, and 70C burst for DISCHARGE. that's 4400 x 40 or 176A constant discharge rate
it's rated at 8C maximum for CHARGE rate. that's a maximum of 4400 x 8 or 35.2A maximum charge rate
hope this clears things up a little ?
jason.
jason.
#2874
RE: Unofficial
Hi all just finally finished reading the whole 115 pages and have an idea of what i am getting and would like to see what others think. I really want a 3S set up and would like it to be bigger than 2040 and mount right up i am open to getting a different coupler as i understand this place has some that will work correct? Anyways i am open to any ideas let me know what you think
motor
ESC
battery
Also will that motor mount to the pump that is my only concern with it.
Thanks, Joe
motor
ESC
battery
Thanks, Joe
#2875
RE: Unofficial
the motor you chose is the only thing I could think of, not being big enough (the length ads more torque from my understanding)
I use a 2848 sized motor, it still fits onto the mount. I drilled an extra hole at the top of the mount to fit 3 screws into the motor instead of just the two original screws...
2848 = 28mm diameter and 48mm in length
The size of the shaft of the motor you chose, would fit straight onto the original coupler, it's 2.3mm...
Hope this helps
Martin
