If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 124 of 131 FirstFirst ... 2474114122123124125126 ... LastLast
Results 3,076 to 3,100 of 3271
  1. #3076
    Join Date
    Jun 2012
    Kewarra BeachQLD, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    Hey guys, long time no post, just got everything working today, but the engine appears to be spinning in the shaft. (Supposed to be same size (2.3mm)http://www.hobbyking.com/hobbyking/s...erCooled_.html) Ideas?
    EDIT: Resolved, well more so was never an issue, I'm blind apparently.
  2. #3077
    Join Date
    Jun 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    On the maiden (Pool test) the engine firstly was running backwards, then decided to unscrew the screw on the shaft, anyone got tips on how to get that back in?
  3. #3078
    Join Date
    Aug 2011
    Hobart TAS, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    With a 1.5mm hex driver?? Not sure I get the question correctly, you mean the grub screw in the coupling?
  4. #3079
    Join Date
    Jun 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    Yes that was exactly what I was after, I couldn't work out if it needed a hex driver or something else. thanks!
    EDIT: The only issue left now is the servo arm pops off after a few minutes, this is my first hobbygrade rc venture, so if there is some way of securing the arm other than just putting it on please inform me
  5. #3080
    sundogz's Avatar
    Join Date
    Nov 2008
    Ozarks, USA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    ORIGINAL: Masman
    The servo arm or 'horn' is secured to the servo with a semi-pointed, short screw.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  6. #3081
    Join Date
    Jan 2012
    Sunshine Coast, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    alright, been an eventful weekend for the tear into...
    Yesterday I brought it up the beach, I even brought the charger and ran that off the car battery (worked a treat)
    We went up with a couple of mates, and I now have a jet boat mate in the making (Just gotta order a new kit... thinking of making an Outrunner on 2S for him)
    After many batteries through the boat, it was sucking in water through the jet drive and it sounded horrible because the drive shaft was vibrating... In the end, I could only JUST get the boat up on plane, there was that much water/vibration happening I have to say, I think salt water is abrassive... compared to running in fresh water, the wear and tear is noticable
    Today I decided to pull the boat down and give it a good once over, new glue, grease every moving part and most importantly, do the sleeve mod!
    The sleve mod came out really good I reckon, I should have done that from the get go... The plastic was ground away, so much so, that I could nearly put the 1/8th inch rod in without driiling!!
    I've got pics of all of this, but need to get them off my camera, I'll post once I've sorted that out
    So, right now, I'm charging my batteries, to take the boat out for a test run. The boat is curing in the sun at the moment
    Cheers
    Martin
  7. #3082
    Join Date
    Jan 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    I should have done that sleeve mod ages ago!!
    The jet drive primes instantly, I can go full pelt across waves, and by the time it hits the top of the next wave, it's primed and pushing through the air to the next wave...
    I also took the chance to reconfigure my ESC, which had a cut-off at 6V!! No wonder my batteries were feeling a bit rough...
    I also adjusted the punch level down by 20%, and I think that combined with the jet drive mod, is what gives me prime so quickly...
    Good times
    Cheers
    Martin
  8. #3083
    Join Date
    Oct 2010
    sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    I think sleeving the drive is the only way to go, well for me anyways... The first 3 boats that i had were terrible from factory, either bent shafts or poor alignment. So by the second i ditched stock drive shafts too and never looked back. Plus its part of the fun.
    Make your mates on 3s..
    SCX10 Truggyx2, Wraith
    Ota R31, 16FM, D3.
  9. #3084
    Wheelnut's Avatar
    Join Date
    Oct 2003
    Annandale, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    I will have all winter to mod my boat. Never got to maiden it do to renovating my master bath this summer myself. Took all summer but I'm very happy with the results.
    So.... I really want to take your advice and do the sleeve mod but I don't know where to begin. I would love to see your pics and suggestions so I understand it fully.
    I will take my time and do it right this winter and be ready for some rapid fun next spring.
    If it\'\'\'\'\'\'\'\'s not broke, fix it until it is
  10. #3085
    Join Date
    Jan 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    ORIGINAL: SkR8Pn
    That'd mean his boat is potentially quicker than mine... HAHAHAHA
    He is on a bit of a budget, so an outrunner on 2S might fit the bill... Plus it'd be more interesting for me to build, as it's a different setup
    ORIGINAL: Wheelnut
    Too easy, I hope the pics make sense
    This is what I used: about 20mm of 1/8th inch copper tube & Tarzan Grip Glue (shoe glue or whatever works just fine... this is what I had)
    1. Pull the drive out of the boat, and take it apart
    2. Where the drive shaft goes through the jet drive, use a 1/8th inch drill to drill a new hole
    3. Slide the copper tube through
    4. glue it in place (I only placed glue on the water side of the jet drive... see pic if that didn't make sense, I only glued once)
    5. let it dry
    6. add marine grease and your rubber seal
    7. assemble the drive
    8. then all is done
    The other thing to check regularly, is the prop... I've run my boat on large sand flats on the out going tides (= wicked currents and sand mounts to jump off )
    The prop is definitely the weaker link, and the blades get steadilly shortened, creating a gap between the tip of the blade and the wall of the jet pump... not ideal at all!!
    New prop, New drive shaft and sleeved jet drive = no water in the boat and better than factory speed/takeoff!
    I added a pic from my beach trip too
    SkR8Pn: Could you please let me know what you have replaced the driveshaft with? And how you got the prop to keep put??
    Cheers
    Martin
ID:	1811312   Click image for larger version.
ID:	1811313   Click image for larger version.
ID:	1811314   Click image for larger version.
ID:	1811315   Click image for larger version.
  11. #3086
    Join Date
    Oct 2010
    sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    ORIGINAL: seehuusen
    Cheers
    Martin
    Don't really have a set rule ondriveshafts, Either what i have laying about or can machine to fit... Between the length of thedriveshaft and the coupler i make, holdthe impellerin place. Hope that helps
    Sorry i didnt reply sooner, i've been busy machining, if you ever need couplers etc let me know
    Ota R31, 16FM, D3.
  12. #3087
    Join Date
    Jul 2012
    SingaporeSingapore, SINGAPORE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    finally received the replacement Leopard 4450 kv motor and tested it out.
    there is smoke and burnt mark spotted on one of the motor cables initially, stopped for a while and continued play with no adnormality, total play time ~ 8 mins.
    setup : Turnigy 60A ESC + Leopard 2040 series 4450kv Motor + 2S 4000mah 40~80C Lipo + Cooling tubes
    so the Outrunner 4400 kv motor will be much faster than Leopard 4450kv motor although their top rpm are almost the same?
    ORIGINAL: sundogz
    ORIGINAL: spektrumFlux
    so the Outrunner 4450kv motor will outperform the Leopard 4450kv Motor?
    I suppose Outrunner motor do not need any water cooling jacket?
    That particular outrunner is much more powerful than the 2040 size Leopard. And because it is not pushed that hard, does not build up as much heat. But if you are concerned about heat, you can do what Damfurst did (see previous post) and make a cooled mount (Good job, Danfurst!)
  13. #3088
    sundogz's Avatar
    Join Date
    Nov 2008
    Ozarks, USA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    ORIGINAL: SkR8Pn
    Sorry i didnt reply sooner, i've been busy machining, if you ever need coupliers etc let me know
    Those are nice looking couplers with the three setscrews on each end. Should be able to balance those easily! What would you have to get for one (shipped in the states)?
  14. #3089
    sundogz's Avatar
    Join Date
    Nov 2008
    Ozarks, USA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    Try it and see! It is a stronger motor at 600watts vs 220 for the Leopard. Sure sounds like you got a bad batch of motors.
  15. #3090
    Join Date
    Jul 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    ok, will probably get the Outrunner.
    btw..any suggestion on where to get the 3.17-2.3 mm coupling?
    Great thanks :-)
    ORIGINAL: sundogz
  16. #3091
    Join Date
    Oct 2010
    sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    ORIGINAL: sundogz
    ORIGINAL: SkR8Pn
    You have a pm mate
    Ota R31, 16FM, D3.
  17. #3092
    sundogz's Avatar
    Join Date
    Nov 2008
    Ozarks, USA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    Thx, J.
  18. #3093
    Wheelnut's Avatar
    Join Date
    Oct 2003
    Annandale, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    Now I'm jealous[&:] pm me too
    I would be happy if somone could just tell me where to get couplers in the US.
  19. #3094
    Join Date
    Jan 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    ORIGINAL: SkR8Pn
    We all get busy from time to time, I've been meaning to re-solder 1 bullet connector, 2 weeks later, nothing has been done about the bullet connector... LOL
    These "kits" look familiar, Maryborough-lad?
    would you mind PMing me,what sort of coin would you want from a fellow forumite for one of those?
    cheers
    Martin
  20. #3095
    Join Date
    Oct 2010
    sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    ORIGINAL: seehuusen
    ORIGINAL: SkR8Pn
    cheers
    Martin
    Lol I do similar things... I'm known to lack motivation working on my own stuff from time to time!
    Ota R31, 16FM, D3.
  21. #3096
    Wheelnut's Avatar
    Join Date
    Oct 2003
    Annandale, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    ORIGINAL: Wheelnut
    ignored once again
  22. #3097
    Join Date
    Oct 2010
    sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    ORIGINAL: Wheelnut
    ORIGINAL: Wheelnut
    ignored once again
    Turn that frown upside down....... you have been inboxed
    Ota R31, 16FM, D3.
  23. #3098
    Join Date
    Jan 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    Hey guys,
    I've started gathering a list of things I need for my next tear into. I've stumbled across a new motor that I think would work wonders as a high powered Tear Into on 3S
    The motor has an additional 160 watts of power compared to my current NQD (760 in total) and a better KV rating in my mind, should be fun
    tried posting this a couple of times, so now it's just going to be a teaser LOL
    Here's the list
    eBay: AU$69.04
    re"> BL2856 3200KV Inrunner Water Cooled Brushless Motor
    re"> 150A Water Cooled ESC 5A BEC For RC Boat
    eBay: AU$6.99
    re"> Coupler 2.3 mm to 4 mm - Brass
    eBay: AU$7.89
    re"> FS-GR3C 2.4Ghz 3CH Failsafe Receiver
    eBay: AU$7.60
    re"> MG995 Servo - Metal Gear, High Speed/ Torque, Digital Servo
    I'll obviously do the sleeving of the drive straight away
    This one will probably also recieve a bit of paint, to try to make it look a bit like my ski boat's colour scheme
    I'll report back when it all starts arriving
    cheers
    Martin
  24. #3099
    Join Date
    Oct 2010
    sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    Sounds good Martin... Even betterare the prices, nice work.
    Ota R31, 16FM, D3.
  25. #3100
    Join Date
    Jul 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Unofficial
    do kindly correct me if my understanding is incorrect for the following...
    suggested motor kv for each types of Lipo.
    2S : 3900~4450 kv Inrunner/Outrunner Motor
    3S : 2900~3600 kv Inrunner/Outrunner Motor
    4S : 2600~ kv Inrunner/Outrunner Motor
    2S*3900 kv = 7.4*3900 = 28860 rpm
    3S*3900 kv = 11.1*3900 = 43290 rpm (is it too high rpm to cause motor overheat rapidly)
    what is the ideal rpm range for motor?
    comparing Inrunner 4400kv vs Outrunner 4400kv motor, Outrunner will have more torque?
    what is the criteria to choose between Inrunner and Outrunner motor?
    Regards :-)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
