Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
Unofficial "NQD" Tear into Jetboat Thread
Speed - Electric For all your electric boating needs.
Old 12-06-2009, 01:52 PM
  #601
Wheelnut
My Feedback: (81)
Wheelnut's Avatar
Default RE: Unofficial
Yeh, good point
But it's not the better choice for aumsdh because the outrunner motor he used is more popular in his Country
Old 12-06-2009, 08:54 PM
  #602
wrangellboy
You can get a similar cooling mount that should work for an outrunner here: http://www.offshoreelectrics.com/pro...rod=ose-509b14
Old 12-06-2009, 10:11 PM
  #603
aum-offshore
The Cooling Plate of Offshoreelectrics.com is CNC machine build. I,m Can't build and difficult work.
But i have
Old 12-06-2009, 10:38 PM
  #604
damfurst
hey aumsdh, I think your cooling plate is great. Your boat runs very good too. What is the thickness of aluminum you use for cooling plate?
Old 12-06-2009, 11:41 PM
  #605
nu_nui
 aumsdh thickness of aluminum cooling plate  6  mm
  nu_nui  thickness of aluminum cooling plate   8  mm
Old 12-07-2009, 01:12 AM
  #606
aum-offshore
ORIGINAL: damfurst
I'm use thickness of aluminum 6.30 mm ( 5083 aluminum type )
Old 12-07-2009, 03:02 AM
  #607
llDemonll
does anyone have a good way to get really sticky servo tape out of a boat? my battery holder is servo-taped to the hull and its really sticky on the last 1"x2" portion and i'm afraid to pull much harder for fear of cracking the hull or damaging it in any way. its been sitting in water for 2-3 days and hasnt become any less-sticky, dunno if theres a better solution i can put in there to get it unstuck or at least get the battery holder out. i can clean up servo tape residue after i get it out
Old 12-07-2009, 04:08 AM
  #608
headhunter23
Are you talking about the hot glue? Cold seemed to work for me.
Old 12-07-2009, 09:19 AM
  #609
sundogz
sundogz's Avatar
ORIGINAL: llDemonll
does anyone have a good way to get really sticky servo tape out of a boat? my battery holder is servo-taped to the hull and its really sticky on the last 1''x2'' portion and i'm afraid to pull much harder for fear of cracking the hull or damaging it in any way. its been sitting in water for 2-3 days and hasnt become any less-sticky, dunno if theres a better solution i can put in there to get it unstuck or at least get the battery holder out. i can clean up servo tape residue after i get it out
The glue is not water-soluable. Like I was telling Wheelnut earlier, you need to cut through the tape with a thin knife to free up the battery holder and then use a solvent (acetone, kerosene, etc) to remove the tape residue. Don't just pull on it as it might damage the hull.
Old 12-07-2009, 08:46 PM
  #610
scavone128
scavone128's Avatar
i just got my nqd boat today and just took a quick look at it and it looks like you have to cut through the hatch to get to the motor?
Old 12-07-2009, 08:53 PM
  #611
ryanwilson277
yup i didnt know that eitheir when i got mine but u should leave about a half inch of plastic between the groove and the cut you make
btw this is crabsticks pic
Old 12-07-2009, 11:31 PM
  #612
Wheelnut
My Feedback: (81)
Wheelnut's Avatar
Wow, you had to cut the hull away to get to the motor? that's a suprise. and not a good one, but you got to do what ya got to do!
Old 12-09-2009, 06:11 PM
  #613
headhunter23
I tried actually separating the top and bottom. No workie, tried with acetone etc, cracked bottom hull a bit. Cutting hatch is so far the only way that keeps the strength of the boat together and can be covered up by the lid. Be sure to pull motor tubes out and goop those, plus take heads off and glue those back in properly with goop or some other sort of silicon, the only other two sources of leaks will be the lid itself and the shaft.
Ivan.
Old 12-09-2009, 06:27 PM
  #614
DRAGONFIRE81M
and headers i had a leak there to . btw boca are now saleing some 2x6x3mm bearings that will work on the stock nqd impeller . i hope the email i sent them a year ago helped there
Old 12-10-2009, 03:42 PM
  #615
ryanwilson277
my hobbyking package came yestarday but it didnt come to my door it came to the post office and i had to get it
Old 12-10-2009, 05:05 PM
  #616
DRAGONFIRE81M
yeah you have to sign for it if no one is home it goes back to the post office
Old 12-10-2009, 05:27 PM
  #617
llDemonll
yea, god. i finally called them and yelled at them a few days ago because my package still hadnt shipped. funny how when you do that, it is shipped out (and marked by hong kong post) as 'left hong kong'
if it doesnt get here in 3-5 days im calling them again and *****ing until i get a refund on the express shipping.
Old 12-10-2009, 05:47 PM
  #618
ryanwilson277
ok i made my water pickup and my water coil today so ill be ready soon. a couple more things to do
Old 12-12-2009, 12:31 PM
  #619
aum-offshore
[youtube]http://www.youtube.com/watch?v=P4_6_As2lKI[/youtube]
Old 12-12-2009, 01:50 PM
  #620
bayshun
bayshun's Avatar
ORIGINAL: llDemonll
hey what i would do is get this stuff called guegon . they have it at wall mart . it will eat threw the tape but not the boat its from oringes
Old 12-13-2009, 11:02 AM
  #621
aum-offshore
Old 12-13-2009, 11:04 AM
  #622
aum-offshore
Old 12-13-2009, 11:09 AM
  #623
Wheelnut
My Feedback: (81)
Wheelnut's Avatar
aumsdh, freakin sweeeet. Awesome idea and pictures. A+++++++++
Can you provide us with some more pictures of your ramp boat and how you built it?
Old 12-13-2009, 11:13 AM
  #624
nomobux
nomobux's Avatar
Box it up . I'll pay shp'g.
Old 12-13-2009, 11:17 AM
  #625
nomobux
nomobux's Avatar
My HC order is in Utah. Creek is frozen. In fact the ice is rising. Here I go again. Last yr I spent Xmas fighting flood water. All the water in the pic is supposed to be on the other side of the trees .. lol
