Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
Unofficial "NQD" Tear into Jetboat Thread
Speed - Electric For all your electric boating needs.
Old 10-02-2009, 10:44 AM
  #126
llDemonll
Default RE: Unofficial
that's bs i just bought them lol
did you contact him through ebay? he has a website www.sedent.de and their email address is [email protected]. i think that's who i emailed first to ask about getting them here. i only found him through ebay, none of the transaction was done through ebay
Old 10-04-2009, 12:51 AM
  #127
jetsprintbasher976
My Feedback: (-1)
hehe lol get the f out i just found a origanal  graupner jetsprint in ohio for 120 the full kit its all mine! and i can get a billings jet boat palm beach edishion with it any one want's  it
Old 10-06-2009, 01:06 AM
  #128
llDemonll
got mine (for the most part) built up. No bearing in the driveshaft yet or sleeve but i'll get to that soon. motor cooling coil was a pre-fab, working on a better one once i find something the right size to wrap around.
may have to play with the battery to get it balanced right, it's decent at the moment but havent had a chance to drive it for very long, been getting a nice seal between the jet drive and the hull.
have a traxxas slash waterproof receiver box, traxxas slash 1/18th waterproof server, walkera 3200 motor, turnigy 35a waterproof esc, turnigy 3000mah lipo (got these for longer run times, 80g more than the 2200mah ones so we figured it was a better investment, hopefully it was and the weight wont be a problem with acceleration and such)
ID:	1289250   Click image for larger version
ID:	1289251   Click image for larger version
ID:	1289252   Click image for larger version
ID:	1289253   Click image for larger version
Old 10-06-2009, 05:37 AM
  #129
sundogz
sundogz's Avatar
Lookin’ good! Try putting the battery horizontally in front of the motor if it will fit. You can cut off the water discharge tube leaving about 5mm sticking out so that you can see the stream to assure the cooling isn't plugged. If I were to change anything, I would have drilled the water line holes directly behind the motor mount screws for easy access to the screws with a long screwdriver. All in all, good looking work. Please post some videos!
Old 10-06-2009, 11:34 AM
  #130
llDemonll
yea, the water tube i've yet to cut off because im just making sure i dont cut it and then change how it is in the boat or anything.
battery i may end up changing, i wanted to keep as much weight back as possible so we'll see how it works. havent driven it yet aside from in the bathtub to make sure it works lol
Old 10-07-2009, 05:00 PM
  #131
llDemonll
So after what I thought was waterproofing it (the seals for the jet drive) it still leaks a bit. and so does the kitchen sink with a boat in it (lol oh well). Did you guys seal the back of the jet drive (without the cowl on) also? I'm thinking that's where it's leaking from still but I'm not sure. I don't have any tools here, I built this at a friends house so before I go and buy allen wrenches (I'm cheap) I wanted to know if you guys sealed the back of the jet drive as well.
Also, is there anything i can do to "waterproof" the lipo's? I'm not too worried about it, as theoretically no water should be getting in once I seal the jet drive and whatever else is leaking, but in case something tragic happens is there a cheap way to do that? maybe heat-shrink it? I just don't want to be too worried about them (not really am, but just taking the extra precautions)
Old 10-07-2009, 07:00 PM
  #132
headhunter23
Demon if they are new packs you have very little chance of anything occurring, i've got... geez dozens o lipo's no fires and all of them dunked or wet. I've found no matter what, you always seem to get water in. But as for securing the jet drive, goop, drop some in and use a toothpick or something long and skinny to move around the jet, for the bottom portion at the back of the boat, make sure your in a room with good heat and put a good dollop in there and just have gravity move it around(which means twisting etc). Let dry for 24 and at least the jet drive will stop leaking except for maybe where the drive shaft is(fixes for this too).
Also be sure to pull the engine pieces out and goop them back in. the main leakin area will then be your top.
Good luck.
Ivan.
Old 10-07-2009, 08:08 PM
  #133
llDemonll
cool, wont worry about the lipo's at all then. not planning on sinking the boat, but if i do manage to that's the only thing that would fail haha.
ill see if i can get a video up over the next few days =)
Old 10-08-2009, 09:44 AM
  #134
sundogz
sundogz's Avatar
I have resorted to supergluing the jet in to stop leaks. I take the jet out, clean all surfaces and c.a. glue it in. After that cures (next day), I run a bead around all the seams again (inside and out), and repeat that twice. No leaks at the jet anymore. Seems the hull flexes and eventually leaks with the factory sealant (silicone or hot glue) but superglue works well. Now the only place it can leak is at the driveshaft seal - but is not a problem - yet!
Headhunter, nice to see you're back in the swing. [8D] Sdg.
Old 10-09-2009, 02:19 AM
  #135
headhunter23
Just like quicksilver now... always lurking but theres so many people to answer stuff...[:-]
Old 10-11-2009, 09:40 PM
  #136
rockwerks
Well I jsut ordered 2 of these to play with in the waves on the beach here. Of course already looking at upgrades. for 29.99 plus shipping it was kinda hard to pass up
Old 10-11-2009, 10:10 PM
  #137
sundogz
sundogz's Avatar
Where did you find these so cheap? (was the shipping pricey?) Sdg
Old 10-14-2009, 04:16 AM
  #138
llDemonll
http://www.zhobby.com/17wajetrcelr.html
http://www.zhobby.com/17wajetrcelr1.html
go fast!
both are in stock, $10 shipping to where I live. bummer i didnt wait, coulda bought 2 for the price of one but oh well!
if electronics werent so expensive i'd buy another
Old 10-14-2009, 08:09 AM
  #139
sundogz
sundogz's Avatar
ORIGINAL: llDemonll
go fast!
Well, since the cat's outta the bag:
http://www.raidentech.com/17wajetrcelr.html
http://www.raidentech.com/17wajetrcelr1.html
(thx,rockwerks!)
I'm thinking of getting (another) myself. I've made all the mistakes, so could now build one that's 'right and proper' from the first cut. I've always wanted a yellow one.
Old 10-14-2009, 04:38 PM
  #140
mineralvann
my god, that made my day. Was considering ordering one of the brutaly overpriced versions
Old 10-14-2009, 08:13 PM
  #141
sundogz
sundogz's Avatar
Good things come to those that wait.
Old 10-16-2009, 12:37 PM
  #142
rockwerks
My 2 showed up today. nice controller! [:@] I have a bunch of IB 1600 2/3a cells lying around that I can make into 10.8V packs they are 30c so power supply should be fine
Did everyones come fully sealed hull?
Old 10-16-2009, 05:25 PM
  #143
wrangellboy
Yeah, mine came fully sealed. Speaking of that. Anyone have any tips about waterproofing around the jet unit? I tried a bead of glue around the outside on the bottom, but mine leaks like a sieve... Maybe silicone caulk?
Old 10-16-2009, 05:30 PM
  #144
llDemonll
i'm still having trouble with that.
the bottom is sealed nicely, so is the back. the only thing i can think of that would be leaking is through the screw holes in the rear? dont ask how but it's the only entrance into the hull that is open still
Old 10-17-2009, 10:43 AM
  #145
rockwerks
ORIGINAL: llDemonll
Have you done a bathtub test? fill the tub with water and place the boat in the tub and watch for leaks, I add a bit of weight to mine to simulate full running weight plus a little
Old 10-17-2009, 12:03 PM
  #146
ryanwilson277
you have to cut out the top
Old 10-17-2009, 02:09 PM
  #147
rockwerks
ORIGINAL: ryanwilson277
Yous should do that anyway before you run it to check for leaks
Old 10-17-2009, 02:33 PM
  #148
llDemonll
i've done the "bathtub" test (kitchen sink lol) and i know there's a nice seal around the whole bottom and back. the water seems to pool on the transom, right under the jet drive in the middle, mostly on the right side looking from the back of the boat. i just went and sat it in the kitchen sink with the battery in it and pushing down on it and wiggling it around every once in a while for ~10 minutes and not a drop of water is in the boat. the only thing i can think of is the screws and the pressure of water in the jet drive while running just forces a little bit through
Old 10-17-2009, 02:35 PM
  #149
wrangellboy
Has anyone tried 5-minute epoxy for gluing the jet unit in? I'm thinking of trying it, but it seems like if it doesn't work I'll be stuck with a big mess...
Old 10-17-2009, 02:37 PM
  #150
llDemonll
i like CA glue best. easy to work with and adds strength to the hull. my friends and i used to 5-15 sec drying time one for our boats
