Unofficial "NQD" Tear into Jetboat Thread
#1902
RE: Unofficial
I almost finished painting one of the boats. I have to get a fine tip paintbrush to finish the windshield. Some of the black paint leak through the tape. Project Mayhem is our paintball team and the other logo's are our sponsors. I still have a couple things to do then give it a clear coat. Still waiting for the rest of the parts. My son changed his mind and went with Rampage and Bonner.
#1904
MT
RE: Unofficial
Just a short vid of a new Tear Into with a 22mm Abc Hobby drive installed. Maiden voyage and no speed passes but overall I think I like this version.
[link]http://www.youtube.com/watch?v=2OlRNzSt_-E[/link]
#1906
ID
RE: Unofficial
Just painted up my new boat:
The motor I ordered for 2S testing showed up today, the 4800kV watercooled one from HK with the 2.3mm shaft. Should put out about 38,000rpm on 2S, hopefully it works!
#1907
RE: Unofficial
Looks good, great job on the paint. I think we have the same motor. Some of my parts showed up today. The Motor,ESC ,radio. Does anybody have a schematic on how to wire it up. There is one in with the ESC but my motor leads and the ESC leads are different colors. I will have to get different connectors for them because they don't match either.
#1908
RE: Unofficial
Hi all,
Great paint jobs. I read most of the thread awhile back and have a few packs through my boat now. Unfortunately, I sucked up a rock and broke the impeller.
I know NQD does not offer replacement impellers. I also understand that a 19mm graupner impeller will work with some modifications (drill jet housing for 3mm shaft).
Does anyone know of a source to purchase the 19mm graupner impeller and shaft? Preferably in the US?
A link would be very helpful. Thanks.
Also, I have heard of people modifying boat props to work as impellers....curious to see if anyone has done this with a 3 blade prop?
THanks,
Hankinator
THanks,
Hankinator
#1909
MT
RE: Unofficial
Here's a link to [link=http://www.cornwallmodelboats.co.uk/acatalog/graupner_jet.html]Cornwall Model Boats[/link] in England. I have ordered from many times and never had a problem. Shipping is very reasonable as well. These look to be in stock as well. I would also suggest installing a 3mmX10mm bearing. These will fit where the rubber seal is.
I believe that someone has done it with a 3 blade prop either dragonfire or headhunter. I don't remember what the outcome was. Hope this was helpful.
#1910
RE: Unofficial
Just stick em together any old way, and if it goes the wrong way, swap two of them.
My ESC didn't have connectors, so I snipped the ends off the motor cables and went for the solder / heatshrink option.
ORIGINAL: t.roy
#1911
ID
RE: Unofficial
Well I put the 4800kV motor in and it seem lethargic on 2S, so I threw the 3S in....Snap! Back to having the crazy punch I was used to having. Hopefully this motor can handle the load.
#1913
ID
RE: Unofficial
Yeah he's a little guy compared to the 2600 I had in there that lasted all of 2 runs....[:@]
I'm running two of those little 3S packs in parallel now, turning the current limiter on my ESC way down and it should be fun times! Hopefully this motor lasts longer.
#1914
RE: Unofficial
aahhhhh, i have that motor on order and i was hoping to run 2s on it. How sluggish are we talking? I don't need crazy speed, but would like to have a little kick for getting up rapids.
#1915
RE: Unofficial
ORIGINAL: MaximuM*AltitudE
#1916
ID
RE: Unofficial
I'll see what I can do, I thought the same thing when I tried it on 2S (just in the bathtub real quick) and it didn't seem to have much snap. Could be my 2S, it's a fullymax cheapo and I haven't had much luck with them except in scale crawlers. Only a 20C/40C burst.
If I could find the right adapter I would rather run the 2600kV 28mm motor I had in it before! I don't think this 4800 will last very long on 3S either, but the snap is sooooo much fun.
#1918
RE: Unofficial
I would like to see a video too. I order the same set up and that bums me out to hear that. I order (3) 2s batteries and (1) 3s battery. Does anybody have any good tips for the water pick up for the watercooling.? I know I have to drill into the stator. What do you guys use brass pipe? I will post some more pictures soon.
#1919
RE: Unofficial
#1920
ID
RE: Unofficial
ORIGINAL: sundogz
Would [link=http://cgi.ebay.com/3-Racing-28mm-Brushless-Motor-Plate-Axial-AX10-Scorpion-/160375925167?pt=Radio_Control_Parts_Accessories&hash=item25572669af]this[/link] work? I use these on the ABC Jet Ski's when upgrading to a 28mm motor.
It bolts right up to the stock mount, I just need to have an adapter for the shaft or convert my NQD pump to the graupner impeller and shaft.
BTW, I ran the boat on 2S and 3S last night (couldn't get a video, the wife didn't want to come lol) but the 2S isn't bad at all now that I have two of them paralleled and fully charged. Ran for about 10 minutes, motor was cold and so was my ESC. Just have to fix a little water leak in the transom. I'll still try to get a video and I'm in the process of finishing my other boat, I'll most likely convert it to the graupner shaft with the 2600kV motor up there.
Definitely a lot of testing and trial and error with these boats but I think both my setups will work! 1 for 2S and 1 for 3S!
For the water pickup I used a small threaded grease fitting. But I would go here for anything to need for watercooling: http://www.kintecracing.com/Water_Cooling_BQFJ.html
They have all the fittings, pickups, lines and waterjackets you would need!
#1921
RE: Unofficial
#1922
ID
RE: Unofficial
Thanks sundogz, those are exactly what I have been looking for! I bought some 2.3-2.3 couplers from that same seller with the intention of drilling one side out, we'll see how it turns out.
I'll try to get a video of my white boat with the 4800 2S in it this weekend, once the coupler shows up I'll get the other boat running on the 2600 3S setup. I have a feeling both should work great, but I'm leaning more towards the 2600 3S with the bigger 28mm motor.
#1923
ID
RE: Unofficial
Well this blows. My impeller shattered today and my boat took a 20 minute trip down the river until I could get it back. Just ordered some graupner impellers from CMB in the UK and I'm going to be doing the shaft mod and then I have couplers that will fit my 2600kV motor.
Sucky part is I have to pull the impeller out of the other boat to have fun this weekend now.
#1924
RE: Unofficial
Oh damn that does suck, I hate that moment when the pitch gets higher and you start looking at your escape route. I always plan ahead but typically play on some fairly low rivers/creeks.
Glad you got it, 20 mins! wowsa.
#1925
ID
RE: Unofficial
ORIGINAL: bjacobsen
My tear into teaser!
