Is this a good Hull Delta 33
MO
http://www.offshoreelectrics.com/pro...rod=df-delta33
Looking for a new project. Wondering if this is a worthy hull?
MO
RE: Is this a good Hull Delta 33
http://www.offshoreelectrics.com/pro...prod=fei-580-L
Do you guys think this is motor will push her to 50-55??
6s Lipo
Is the 540 to small?
First Electric build, always bought RTR and modded them. Thanks for all the help. I want to do it right.
6s Lipo
The DF33 is an excellent hull and will easily achieve 50+ mph on 4S. An excellent thread with multi builds for the DF33 is here:
http://www.rumrunnerracing.com/fefor...ad.php?t=25916
All the best,
Ray
All the best,
Ray
ORIGINAL: LouDog
With 8s lipo do you think 50? Thanks for the quick response.
It depends far more on the motor and ESC that you choose than the hull itself. I would absolutely plan on running it on 4S and then make your go fast decision based on the motor and ESC.
MO
Thanks Silent. You have brought up another question for me? What is the difference between the Cyber and the regular DF33? Is it just length and width?
BC, CANADA
The DF Cyber has a much deeper vee than the DF33 hull. There is a slight difference in dims too. The Cyber measures 32.25" x 9.25" and the DF33 comes in at 33.25" x 10.25". So about an inch in length and width.
http://www.deltaforce-hk.com/images/...Back_S_800.jpg
Read the link to the DF33 thread posted by Ray. Good information in there. I have a DF Cyber that hopefully should be here soon. I am planning of running an outrunner for this hull on 5s.
