Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
Norbert's 1.1m balsa cat build
Speed - Electric For all your electric boating needs.
Old 09-02-2012, 09:59 PM
  #226
norbique
norbique's Avatar
Default RE: Norbert's 1.1m balsa cat build
Those 1400KV T600 Turnigy motors are good. I bought them while they were only $30 + sh, now they're $60 +sh but still worth it.
Old 09-02-2012, 11:05 PM
  #227
colosus
colosus's Avatar
Thanx Norbert...
Loadsa info...excellent job..
So both low or high Kv motors could give same performance depending on what setup you will use... i.e how many cells or Lipos and what speed controller you use...controller must support the amp of how many cells u will use ... so the lower the Kv more cells needed and the higher Kv less cells needed...
A 3000-4000Kv only needs like 3s unless Amps needed to run motor was higher then it can take more cells ?
So i could use for example the Scoprion 3226/1600kv for Helicopter motors....meaning less batteries to use...but then Amp is low...which does not mean a fast setup...
like i said my Lehner 2250 needs 160amps... 24 cells ..all ready using a speed controller in the 300+ euros...and this is pure power...with that motor and good prop setup the boat will do over 100kph ...100% ....how can a lower ampage motor get those types of speed if it had less batteries to run it...??
you didnt mention anything about Amps ...so now me a little confused..i thought the higher the amp the more powerfull the motor ..?
I know they are two different things Amp and Kv, i'm just waking up hehe when i write this so do excuse my simple mind....its not working right yet...more coffee...
Old 09-02-2012, 11:21 PM
  #228
ThomasSalin
I just printed the plans, this will be a nice winter project..
///Thomas
Old 09-03-2012, 01:11 AM
  #229
Goldenduff
Lower ampage could the same speed by using a higher pitch prop with smaller diameter prop- so less thrust/acc.....I think!!
Old 09-03-2012, 09:18 PM
  #230
norbique
norbique's Avatar
We must clearify something here.
It's not the prop size/pitch that's the first thing to make a boat faster, but power is.
Power = Voltage * Current
So to go back to the debate of HV and LV setup heres a little maths (this is theory, I don't bother with motor/esc efficiency, power loss due to friction etc.):
Let's suppose we need 2kW of power to push our hull decently. Lets see how much current would such a setup require:
Power = Voltage * Current -> Current = Power / Voltage
LV setup: 6S pack Current = 2000W / 22.2V = 90A
HV setup: 12S pack Current = 2000W / 44.4V = 45A
This shows clearly how things are related. The HV setup would run less amps for the exact same amount of watts in. And the less the current, the less the heat loss which also means higher efficiency.
We can also see since the HV setup needs lower current from our packs for the same amount of motor power, the packs will hold their voltage higher, this will also result in a faster running boat. We can generally say the less the current the better off we are. Unfortunately, the HV ESCs are more expensive than the LV ones mostly because of the higher voltage MosFET transistors used in them. this is the only reason I stuck with the LV setup.
Old 09-04-2012, 12:45 AM
  #231
Goldenduff
Agreed but lets be clear that raw power with incorrect prop can be slower than less power with perfect prop!
Old 09-04-2012, 01:31 AM
  #232
colosus
colosus's Avatar
hmmmm...me still confused.... lol
This Lehner 2250 9winds 160amp motor cost me almost 300euros, how can a motor of less the 100euros ever be comparible, how can you compare the two ..ok compare is the wrong word but... 160amp thats a lot man..and almost any controller needed for that motor will cost between 250 to 390 or more..
For example Norbert...if you take 2 of these motors i have and put those in your Lithium Cat along with 48 cells or..em how many lipos i forget, then your cat will be very very fast..much faster than you got it already..i know this because my same motor is used for HPR boats and MHZ ....but then your talkng silly money for the lipos and controllers...
so i'm still no clearer on how to save money on motors & setups but still have mega speed....how i now see it is if you want speed...your'll have to pay for it..reason i brought this to light is because there's so many motors on the market i got no idea where to start or what to get.. motors 4pole and so on ....some Leopard motors and fast too..there must be about 20 different Leopard motors to choose from....now i seen vids on youtube running Leopard motors then finding out there are other Leopard motors they could have used...why did they get this particular motor.....an not the other..depends on there own setups, yes..but thats not what i mean..its the series of motor..4092 or 4068 or 5698 and it goes on ...lol..
what is it you need to look for to know that your boat will go fast with this motor and this amount of batteries..?? knowing that we're not buying motors made for boats..
http://www.youtube.com/watch?NR=1&v=...M&feature=fvwp
Old 09-04-2012, 04:11 AM
  #233
ThomasSalin
when using counter rotating propellers .. do you also use flex cable suitable for counter rotating?
I hope You understand my question
///Thomas
Old 09-04-2012, 04:25 AM
  #234
norbique
norbique's Avatar
ORIGINAL: ThomasSalin
///Thomas
YES counter rotating flex shaft is a must.
Old 09-04-2012, 04:28 AM
  #235
ThomasSalin
was the counter rotating flex shaft standard on the stinger or did You have to modifie it?
Old 09-04-2012, 05:51 AM
  #236
norbique
norbique's Avatar
I bought the normal and reverse rotating flex shafts separately. made my own propshafts, drivedogs and couplers.
Old 09-04-2012, 09:27 PM
  #237
ThomasSalin
What could be a good motor/esc combo if I would use only a single motor on this bull?
///Thomas
Old 09-05-2012, 02:50 AM
  #238
norbique
norbique's Avatar
Don't know what motor you should use, but look for something that's in the 4+ kW range.
Old 09-07-2012, 11:48 PM
  #239
colosus
colosus's Avatar
yea..the only thing is you will never get the speeds needed for this boat with one motor setup...unless you went for a motor like i got for example 2250/9 HiAmp 160amp, HPR boats are using same and even 2280/7 and now in the 3000 series 196kmh but these cost loadsa cash..if i get another 2250/9 i know for sure this boat will rocket...
Neumotors too cost loads..
I did some research over the years..latest fast motor used are Scorpions:
2x Scorpion 5035/760kv with 2x 12S1P Turnigy Nanotech 5000 45C = but these cost like the Lehner motors
Then less price motors like :
Tenshock motors 2250/7 at 136kmh http://www.tenshock-motors.de/
feigao 540 6XL will be fast as a single motor but needs very good cooling
2x leopard 4074 2000kv 6s at 133kmh
and 2x Leopard 4082 2200kv going at 154kmh = $75 each motor (i would be buying something like this for this Cat build)
http://www.youtube.com/watch?v=JvWEU...feature=relmfu
Seaking 180A
These motors have been test in MHZ Mystic 114 & HPR 115, just type straight in youtube '' mystic 114 '' it will come up with loadsa vids and there setup specs...this will give you an idea..
Hope this helps..
I found a nice controller too.
HV 220A Opto PRO II Navy Competition Brushless ESC (10-40 Opto)
[E065] $259.00
Old 09-16-2012, 02:27 PM
  #240
baadebygger
Very nice work Norbert.
I consider to build a Cataraman. Are about to do a Smit Rotterdam and the Admiral (Old Costum- control mahagony cruiser)from DMI/Billings.
Greatings from Esbjerg, Denmark
Old 09-25-2012, 09:02 AM
  #241
mike52869
Norbert: If you could send me a set of plans I would be greatly thankful!
Mike           [email protected]
Old 06-05-2015, 11:45 AM
  #242
BIKERBOBW
Good Day Norbert
I tryed the link for your plans but did not appear to work for me
Could you email me a set to [email protected]
1.1 metre size is good
Old 06-13-2015, 03:35 AM
  #243
BIKERBOBW
Mike********* *[email protected]
good day sir
See you requested plans in 2012
If you still have the plans could I get a copy if possible
Email [email protected]
Have tried the links and Norbert with no luck
Thanls
Old 06-13-2015, 06:33 AM
  #244
norbique
norbique's Avatar
I've just emailed the plans to you Bikerbob.
Hope it shows up.
Happy building!
Old 06-13-2015, 01:22 PM
  #245
BIKERBOBW
Thank you Plans arrived
Old 11-03-2015, 09:24 AM
  #246
danielq
Hello guys, I just wrote to norbique but maybe he is still busy, could anyone send me the plans ? or maybe someone have some 3d cad drawing? (I will send in a PM the mail)
thanks everybody
Old 04-30-2020, 06:21 AM
  #247
Chrisg81983
Hello all i know its been a while and might be a long shot, but would someone have these plans. Thanks in advance.
