Speed - Electric For all your electric boating needs.
Norbert's 1.1m balsa cat build
Reply
Old 06-02-2009, 04:04 PM
norbique
norbique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Norbert's 1.1m balsa cat build
Hi!
I've already promised to some of you that I'll post a thread showing my 1.1m balsa cat scratch build.
Not long ago I built a balsa cat per Shockerman's plans at 80% size of the original plans. I liked the boat so much that I decided to build it agan, but this time enlarged.
I very slightly modded the plans and enlarged them to 166%. Most of the pics speak for themselves, some I will comment.
All comments suggestions are welcome!
n.
ID:	1210800   Click image for larger version
ID:	1210801   Click image for larger version
ID:	1210802   Click image for larger version
ID:	1210803   Click image for larger version
ID:	1210805   Click image for larger version
ID:	1210806   Click image for larger version
ID:	1210807   Click image for larger version
ID:	1210808   Click image for larger version
norbique is offline
Old 06-02-2009, 07:47 PM
SV27dayton
SV27dayton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Norbert's 1.1m balsa cat build
Love that boat.  I gotta finish mine.
SV27dayton is offline
Old 06-03-2009, 01:04 AM
Stokes
Stokes's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looking good buddy....and the small one - that's quality that is.....excellent stuff - keep it up!!!! Is the hull bottom also balsa? if you want it to be stronger maybe modelling ply (1mm) would suit you better, and just as easy to cut with a Stanley knife...my only doubt is the strength of balsa for a boat this big (and this powerful). ok you'll glass over it, but still, I think ply might be better.
keep the pics coming!
Dayton - you still not finished ?
Stokes is offline
Old 06-03-2009, 01:32 AM
norbique
norbique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SV27dayton, Stokes,
Thanks for the kind words! I'm always trying to be as precise as possible when I work.
The small boat's shell is made of 1.5mm balsa laminated with 0.4mm 3 layer ply. It's very strong. The ply does wonders.
The light blue coating is actually a 2 component base coat. It is sprayed over and it fills the grains very nicely. When it dries it feels like it's some kind of a plastic, still it's easy to sand. I still haven't decided on the color. Maybe light blue metallic.
The big cat will have 3mm balsa on the bottom and the sides, 2mm balsa on the top, and everything will be laminated with either 0.8mm or 1mm ply. Plus I'm thinking of adding 2 or 4 carbon pipes going through the hull lengthwise and woven glass fiber reinforcement from the inside of the hull.
norbique is offline
Old 06-03-2009, 03:14 AM
Simon.O.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Norbert.
I will watch and help where I can.
My next build of a Cat will be a twin drive, no surprise there. It will however be small, about 20 inch long with Mystery style heli motors. This is to keep the cost low and fun high.
Balsa build all the way with a bit of hardwood here and there for strength.
Varnish, sand, varnish sand etc............then water time.
Simon.O. is offline
Old 06-03-2009, 07:01 AM
SV27dayton
SV27dayton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not sure if the ply is the same.  I think I used Birch.  Looks like there are 3 or 4 layers - very thin, but I think way more impact resistant.  That paint sounds really cool.  Mine will maintain it's natural finish but I'll remember that for later.  If I do an F1 I'll paint it.
Stokes - My life must be too full of good things!  (one of them isn't money)[:@]  (and another isn't spare time)[&:]
Old 06-03-2009, 09:45 AM
norbique
norbique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some new pictures.
ID:	1211232   Click image for larger version
ID:	1211233   Click image for larger version
ID:	1211234   Click image for larger version
ID:	1211235   Click image for larger version
ID:	1211237   Click image for larger version
ID:	1211238   Click image for larger version
norbique is offline
Old 06-05-2009, 10:49 AM
norbique
norbique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Picture update agian.
I was working on the rudder holder (sorry, I don't know the name) of the boat. I looked at some (many) cat pics and took the shape from there. Then I designed something similar. It turned out quite well. I bough some SS lock nuts and bolts, M4. Those will hold the rudder mechanism in place.
I also added the carbon pipes, 5mm outside diameter. I had to do it in two pieces because of the shape of the hull. I will reinforce the joints at bulk "C" where the two pipes meet with ply on boths sides just to make sure. I was wondering should I sand the carbon a little bit where the epoxy will be added, since the surface of the pipe is so smooth.
ID:	1212277   Click image for larger version
ID:	1212278   Click image for larger version
ID:	1212279   Click image for larger version
ID:	1212280   Click image for larger version
ID:	1212282   Click image for larger version
norbique is offline
Old 06-06-2009, 12:59 AM
justintime2w8
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow your work is incredible, I am now roasting marshmallow's in the backyard over the three I built :-)
justintime2w8 is offline
Old 06-07-2009, 03:24 PM
norbique
norbique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Thanks justintime!
I did some work today. I epoxied the rear segments of the carbon reinforcements, the last bulkhead, and began planking the underside of the tunnel with 3mm balsa.
ID:	1213502   Click image for larger version
ID:	1213503   Click image for larger version
norbique is offline
Old 06-07-2009, 04:04 PM
Stokes
Stokes's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
keep going.....definitely an inspiration to us all!!!!
Stokes is offline
Old 06-08-2009, 04:36 PM
norbique
norbique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I glued the front segments of the carbon pipes in place. These carbon pipes make a huge difference. The hull is already very rigid thanks to them, although it still has a little torsion play of about 2-3mm. But considering the hull is more than a meter long, it's quite good I think. I cut and glued reinforcing ply pieces to the front of the sponsons, see pics. Then I worked on the rudder holder. I carefuly drilled the 4 holes for the bolts through the ply. I wanted to make them nice and parallel to each other. Then glued the M4 self-locking SS nuts to the indside of the rudder holder with a tiny drop of CA, just to hold them in place. Then I surrounded the nuts with clear epoxy. Not much work but it took quite some time....
ID:	1214508   Click image for larger version
ID:	1214509   Click image for larger version
ID:	1214510   Click image for larger version
norbique is offline
Old 06-08-2009, 05:33 PM
Jackedman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
norbique you are one fast worker and do very nice work i might add. You said you were going to paint it an light blue metallic may i add to say add some silver metal flake to it or even an darker blue i use it in a lot of my trucks and it looks crazy , But really nice work cant wait to see more pics
Jackedman is offline
Old 06-09-2009, 07:16 AM
norbique
norbique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the compliments and suggestions Jackedman!
Can you post a pic of your truck here just to show us how it really looks? A daylight pic would be best, as artificial light screws up the metallic paint color, or the camera white balance or somethin, but it doesn't look the same as in natural light.
Another quesiton, where can one find those silver metal flakes you mentioned? It's kinda hard to find these kind of exotic stuff on this side of the pond you know.
More pics will come later today. I was repairing an office desk in the morning. Didn't touch the cat at all.
norbique is offline
Old 06-09-2009, 11:21 AM
Jackedman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will take some pictures for you and post them I have a few trucks i have done this too and all the metal flake that i use is just the fine glitter ( craft glitter ) and some clear coat mixed together but try it out on a scrap peice first .
Old 06-09-2009, 04:31 PM
Jackedman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hope this helps but if needed i can take some more pics
ID:	1215307   Click image for larger version
ID:	1215308   Click image for larger version
ID:	1215309   Click image for larger version
Old 06-10-2009, 06:19 AM
norbique
norbique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank for the pictures Jackedman, it looks really nice.
How do you apply this glitter? You can't spray it on, right?! The flakes are too big to go through the nozle of the spraying gun.
I didn't make any new pics, since I only varnished certain parts of the inside of the hull, which will not be accessible once I plank those parts. I'm gonna give two layers of varnish, then I can continue with the planking.
norbique is offline
Old 06-10-2009, 03:30 PM
norbique
norbique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I coated the parts I refered to earlier with two coats of varnish, and continued planking the bottom of the tunnel. I also worked on the rudder holder.
Now it's beginning to look something like a boat, not just a skeleton Current weight as shown in the pictures is 652g.
ID:	1215858   Click image for larger version
norbique is offline
Old 06-11-2009, 12:27 AM
Stokes
Stokes's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
did you epoxy in the transom bolts? useful trick that...in some boats I own it's a bloody nightmare to get an allen-key/screw driver in there. The only downside is that you can't use some of the tasty hardware hopf make, as you screw that in from the inside of the transom, but what the hell, plenty of manufacturers to choose from.
Stokes is offline
Old 06-11-2009, 02:04 AM
norbique
norbique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes I epoxied the nuts in their place. The hardware I have (Marine Specialties) is made to be mounted like that. The bolts holding the rudder mechanism are screwed in from the outside.
norbique is offline
Old 06-11-2009, 02:45 PM
Jackedman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
norbique
the glitter you can put it threw a air brush but just put the bigger neddle in and make sure you mix it with clear coat and that should work for you
Old 06-11-2009, 04:30 PM
norbique
norbique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Jackedman, I'll keep that in mind when I get to painting the boat.
I began planking the sponsons of the boat today, but I could only make a single picture, before the batteries in my camera died
norbique is offline
Old 06-11-2009, 04:33 PM
Jackedman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no when your done that you round all the edges and do the other side right or do you do all your sanding later??
Old 07-02-2009, 08:30 AM
norbique
norbique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After such a long time, here's a new pic.
I added two 3x4mm cross section wood pieces to help shape the edge of the sponson and did some more planking. And I ran out of 3mm balsa...
norbique is offline
Old 07-03-2009, 03:11 AM
norbique
norbique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found some more 3mm balsa, so I could finish the planking of the underside of the sponsons.
ID:	1228969   Click image for larger version
ID:	1228970   Click image for larger version
ID:	1228971   Click image for larger version
ID:	1228972   Click image for larger version
ID:	1228974   Click image for larger version
ID:	1228975   Click image for larger version
norbique is offline
Reply
Display Modes
