Can I use this battery question
IA
I have a Super V27 and a Aquacraft Hammer - can I use the 6 cell battery that are 1.2V each in the hammer - they are 4200 mah
I built the batteries at the hobby shop for the Super V but would like to use them in the Hammer also - just wanted to make sure that I would not burn any thing up
thanks for the reply and help
RE: Can I use this battery question
Here is what is listed for the Hammer as far as battery specs, according to aquacraft you can use up to a 7 cell. Your 6 cell is 7.2 volts and a 7 is 8.4. You should be fine with the six ( i'd run a seven myself).
INCLUDES: One assembled Hobbico Hammer boat with 550-size motor, 2ch radio,
system, Electronic Speed Control, illustrated instruction manual,
plastic display stand, and decal sheet
REQUIRES: 6 or 7 cell flat battery pack, battery charger, 8 AA batteries for
radio
radio
