Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
32' cat twin powered
Speed - Electric For all your electric boating needs.
Old 01-04-2010, 04:26 AM
  #101
gen3v8
gen3v8's Avatar
Default RE: 32' cat twin powered
Ran the cat again 2 runs with similar speeds. Hers a vid uncut with gps.
[youtube]http://www.youtube.com/watch?v=LXUDYi7oeqg[/youtube]
Old 01-04-2010, 05:28 AM
  #102
Rull
Hi gen3v8
First of all be careful with props!
First make ruder`s position, then connect battery! The props blades are wery sharp and quick! Take care!
Colud you show me the Center of Gravity of your hull, including GPS in the hull? Show me a marker on the deck cover with a rule or measure it.
What the the current per motors?
Thank you!
Old 01-04-2010, 12:29 PM
  #103
BACKEMF
BACKEMF's Avatar
ORIGINAL: gen3v8
The weight is 3.45kilos It has twin 3650 Flyermate outrunners on 100a flyermate esc and 8x2300 a123 per motor. 4mm flex shafts with modded x442 l&r props. I have only ran the boat 4 times and i`m a bit unsure of it but it does handle very well I think. Need to learn much more.
What size and kv are your motors???
I can't find them online...
What voltage does each motor see?
Old 01-04-2010, 12:47 PM
  #104
Rull
To BACKEMF
ORIGINAL: gen3v8
Ran my cat again today and got some good results.
PS the motors are hobbymate b3650 1700kva.
5cell 2300ma x3.2volt 73.7km/h. Just to clear the grease in shafts a bit.
8cell same batts 105km/h...65.2mp/h. Very stable on glassy water, sorry dunno the terms too new into boats
But 3.2 Volt per cell is too high figure. I guess 2.5-2.7 Volt per cell under load according PDF.
File Type: pdf
Old 01-05-2010, 03:52 AM
  #105
gen3v8
gen3v8's Avatar
ORIGINAL: Rull
To BACKEMF
ORIGINAL: gen3v8
Yes Rull that is possible. Now calculate What rpm is needed to achieve the 64mp/h through the x442 props and don`t even take thrust losses/slipage into account. Then work out how many volts needed to turn them that fast. You will be surprised
Old 01-05-2010, 03:54 AM
  #106
gen3v8
gen3v8's Avatar
ORIGINAL: BACKEMF
ORIGINAL: gen3v8
Sorry hobbymate hb3650
Old 01-05-2010, 12:47 PM
  #107
srt10
My Feedback: (20)
ORIGINAL: Rull
To BACKEMF
ORIGINAL: gen3v8
actualy the 123 packs have an advertised rating of 3.3v per cell and that's what every one uses to setup their baots and cars.. fully charged they are much higher, I think 4v per cell
it all the batteries C rating and amp draw to what the batteries can deliver
Old 01-05-2010, 12:59 PM
  #108
srt10
My Feedback: (20)
ORIGINAL: gen3v8
wow!
Old 01-05-2010, 01:11 PM
  #109
Rull
Ok
8*3.3V=26.4V
26.4V*1700=44 880 rev/min- Can`t belive that the outrunner can handle this revolutions but it is fact.
X442 - 42 mm *1.4 =58.8 mm/rev
58.8*44 880=2 638 944 mm/min = 2.64 km/ min = 158 km/h
incliding slippage20% and motor efficiency80% : 158*0.8*0.8= 101km/h. Cool!
Old 01-09-2010, 05:44 AM
  #110
norbique
norbique's Avatar
Hi gen3v8, your cat is amazing. I'm building one 44 inch cat from scratch and I'm looking for setup possibilities and want to ask you what ESCs are you using that can handle the 8S A123?! I was also thinking in A123's, 8S2P per motor, but 32pc A123 cells cost a hell of a lot of money!
Rull, your build is amazing. You caught me with your own design ESC. Hats off to you! I designed some brushed ESCs some years ago, but didn't bother with the BL since I'm not really familiar with programming uProcessors, and since Chinese offer us their cheapo ESC for modification Could you tell me more of your ESC? Parameters. Will you use D2Pak FETs instead of the TO220 in your first design?
Old 01-09-2010, 08:23 AM
  #111
Rull
Hi Norbique!
Thank you!
I suppose 200A continuous current. I need some thermal tests before characterization..
For the motors I will cut ESC up to 1/2 or 2/3 of lenght and willl have 100 or 150A accordingly.
The 50 D2pak fets IRL7833S are bought for the ESC.
Old 01-09-2010, 08:25 AM
  #112
gen3v8
gen3v8's Avatar
[quote]ORIGINAL: norbique
Flyermate esc`s and A123s from china out of US drills, new $200 for 30 cells
Old 01-09-2010, 08:29 AM
  #113
Rull
gen3v8
Please answer to post #102
Thank you!
Old 01-09-2010, 12:46 PM
  #114
srt10
My Feedback: (20)
ORIGINAL: norbique
many 100A and + esc will handle 8s lipo without issues (more volts than 8sA123)
Old 01-09-2010, 12:48 PM
  #115
srt10
My Feedback: (20)
ORIGINAL: Rull
gen3v8
Thank you!
If your looking for COG, start at 30% from stransom
33% for more control and 28% and less for the most speed
Old 01-09-2010, 01:20 PM
  #116
Rull
Thanks srt10!
Old 01-09-2010, 06:25 PM
  #117
srt10
My Feedback: (20)
ORIGINAL: Rull
Thanks srt10!
right on Rull!
I've got a Mean Machine that I have set at 27-28% COG, and it runs best at that..
Old 01-11-2010, 03:28 AM
  #118
gen3v8
gen3v8's Avatar
OK Rull I will do this w/e Been to busy. Sorry
I will mention at this point. When the 70g gps is fitted in the rear the boat does want to stand up on the props sometimes into the wind.
Old 01-11-2010, 03:39 PM
  #119
500575
That is a good looking hull if you don't mind who makes it or did you?
Old 01-13-2010, 03:38 PM
  #120
Rull
Few new pics
Painting in a bathroom
Old 01-13-2010, 06:09 PM
  #121
500575
I don't know if they are still out there but I bought 20 10,000 mah single cell lipos I just build whatever voltage I think my boat and motor will handle this way you can put cells where you want the weight and have major run time and a lot of amps if I am running a big motor I put cooling plates between the cells that way every thing is watercooled I have 1 motor that is rated at 120 amps a 25 volts I think if my math is right that is 4 plus hp and it is a 2250kv motor so it turns pretty fast hard to keep a drive in it though
Old 01-25-2010, 01:35 PM
  #122
Rull
Fake hydraulic steering control
So all outboat hardware complete. Need only assembly them.
Old 01-25-2010, 04:02 PM
  #123
srt10
My Feedback: (20)
very cool!
Old 01-25-2010, 05:39 PM
  #124
BACKEMF
BACKEMF's Avatar
Thanks Serge, I could make similar now that you have shown me how.
does aluminum slide on each other? do you lubricate it? or are you not finished yet.
I have a lathe only, no mill but, I could make the square parts by hand. Very cool my friend!!![8D]
Old 01-25-2010, 05:40 PM
  #125
BACKEMF
BACKEMF's Avatar
What are dimensions please, thank you?
