Mystic build
RE: Mystic build
ORIGINAL: Gerwin Brommer
Did you modify the propshafts yourself ? As they are from MHZ they had/have a 2mm bore.......
RE: Mystic build
ORIGINAL: wetsleeves
JC, There are two ponds near my house which I run my electric boats, and nitro.
Ive ran the big gas cat there as well.
When the weather gets a little better Ill take a few pics of the ponds and post them here.
The only problem is it gets a little muddy on the banks, so gum boots are a must.
Anyway her are pics of the two ponds.
This is the first pond
#32
IN
RE: Mystic build
very nice built...do u have a close pic of the rudder and the linkage, just wanna see how it works..
btw, i have a mystic boat too!..but just a poster in my wall
#33
RE: Mystic build
The rudder has fake rams which I had to connected Stainless steel cable to(wire trace line that you would use for fishing) which is connected to the servo. I used alaminium rod and connected the wire to it as the rod you get with the rudder is stainless and its not pre drilled.
Here are a few pics, sorry for the clarity.
#34
RE: Mystic build
Hi, thought id share a little update about my boat, well finally I received my batteries after a 4 month wait. I connected a battery to my first Castle HV 120 ESC and everything is ok.
It armed. Connected the battery to the second esc and bang FIRE. Know I have to send the second esc back for another exchange. Why dont they test these esc before sending them out. I dont think I would ever purchase another castle creations ESC again after what Ive been through!!!!!!
Boats back on the shelve for another couple of months until I get my replacement.
Peter
Peter
