Traxxas Nautica ESC Specs?
NJ
I am planning on upgrading a toy grade boat that I have and I want to use the specs of the Traxxas Blast as a guideline. The only info I couldn't find about the Nautica ESC was the maximum number of amps- can anyone help me out?
RE: Traxxas Nautica ESC Specs?
What information are you looking for? its rated at 8.4v 7cell nimh or nicd. doesnt have a low voltage cut off so not lipo friendly must use a external low voltage if you want to use lipos with it. Why use that esc? Show us your boat and what your plans are...
Oic whoopsy i thought that was the only thing you found. Dont know much about the traxxas blast but if your going to use a 540 motor i would go off the motor that came with it or something simialar such as the mabuchi 7520. At maximum efficiency it pulls 13 amps. Other than that i would email traxxas. Are you trying to put a larger motor in? Or lower turn?
http://www.alphalanding.com/rc-track/rs_540rhsh.pdf
