what do FETS do on an ESC
could people please tell me what FETS on an ESCdo please ???
could i remove a FET board of one esc and put it on the same make and model ESC, i ask because i knakered a turnigy 120a speedo (somehow, the motor just spins to full chat) and want to use as much of the parts as i can so i'm thinking about putting the FET board on my working esc (plus another cooling plate)
many thanks
many thanks
If your esc is brushless then it is not the fets at fault.
Trust me on that.
Trust me on that.
yeah it's a BL esc, so what do you think the problem could be then ??
i've checked all the ESC settings with my program card and there all factory set, i did'nt change any of them
ihave tried different motors, different batts even tested everything on my other esc, everything works properly and its not the settings on the transmitter either, it's down to the esc only
A processor in brushless esc switches the six groups of fets in an ordered sequence to turn the motor.
It must still be doing that.
a bit like HT leads in a car ??
what can i do about it ??
thanks for your replys
To save on heatshrink,I would first double and triple check it is not something you overlooked.
Satisfied on the above,If you had access to a voltage scope (or a digital meter at a push) and posted high def pictures of both sides of the boards then an engineer might direct you.
I think you should give it to an engineer to look at.
ok mate, i'll give that a go and see what he says
I didn't actually mean return to base.Just a friend or contact.
If anything,it is usually an esc fet that would blow.Someone conversant with esc automatically check things you might not think of.Stuff like is it actually in idling/half power mode due to low battery?
There is the off chance they would fix any non-FET fault
Maybe there is an esc forum.
the fets look fine to me, i have had a look at the esc and cant see any visible eveidence of anything gone wrong, it was a spare i used for testing bench setups anyway, so i might aswell chuck but see what i can salvage of it before i do
MI
if your fets were the issue youd have little or no power, if it worked at all. whatever your problem is, its tellin gthe fets to switch at WOT- sounds like a processor issue to me.
Previous Thread
Next Thread
