Speed - Electric For all your electric boating needs.
HK Small Bolt Hydro same as HOTR
Reply
Old 09-28-2012, 02:19 PM
  #1201
Rake
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: HK Small Bolt Hydro same as HOTR
I'm beginning to think the old 2600 might have to make a come back if what landor is saying is true.
Rake is offline
Old 09-28-2012, 07:40 PM
  #1202
carakter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In my brief experience with boat motor swaps, all the 2 pole motors I used have gone up in smoke.
Which is Why I now look for 4 pole inrunners. Outrunners have more poles (more torque!), but cooling is an issue.
carakter is offline
Old 09-28-2012, 11:45 PM
  #1203
Landor
Landor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some testing today...
Leopard 2445 3400kv
x432
Turnigy Marine 60A
http://www.hobbyking.com/hobbyking/s..._Boat_ESC.html
Turnigy nano-tech 2200mah 2S 35~70C Lipo Pack
http://www.hobbyking.com/hobbyking/s...dProduct=11943
Top speed: 46 km/h
Motor temp: running cool
Turnigy nano-tech 2250mah 3S 65~130C Lipo Pack
http://www.hobbyking.com/hobbyking/s...dProduct=19123
Top speed: 40 km/h one peak and second best 34 km/h
Motor temp: warm-hot
Turnigy nano-tech 1300mAh 4S 45~90C Lipo Pack
http://www.hobbyking.com/hobbyking/s...dProduct=18208
Top speed: 44 km/h
...so instead of complaining about lack of motor torque the batteries may have difficulties to deliver enough juice. Only the 2s battery was running well. With other batteries there was instant lipo cutoff. With the 4s battery this is understandable. But on paper the 3s battery should deliver plenty of power - in practise not. Or is it anyway a motor torque issue?
Landor is offline
Old 09-29-2012, 05:11 AM
  #1204
Landor
Landor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New test with two of these in series...
Voltage: 4s2p
Top speed: 71 km/h
Motor temp: cool (but only 60 s runtime)
This time there was not any sign of lipocutoff. I did two max. speed passes. Both enend to flips, so the 71 km/h speed is most likely not the best from this setup. The servo broke after the second pass. One plastic gear broke. At least the second pass ended when nose rised nicely upwards.The weather was not optimal, a bit too rough. I am not really familar how much you can change the behavior with strut adjustment.
Other thing I changed since the earlier post was that I did some propeller sharpening and polishing. There was not any clear problem with it earlier I just did it when doing the same for few other propellers. Im not sure if this can explain why the 3s 2,2 Ah 65C battery didn't work last time. Unfortunatelly I didn't have a chance to test it now.
Landor is offline
Old 09-29-2012, 07:59 AM
  #1205
Landor
Landor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
...and story continues...
Two of these...
Voltage: 4s2p
Top speed: 72 km/h just before flipping
Motor temp: hot (3,5 min run time)
The max. pass was the only full throtle try. That ended to flip. The setup difference this time was that I turned the propeller lower than last time. Didn't see much change. The wearher was now better than last time. At least the torque twist seems to try to flip the boat clockwise around. This effect started to be strong already in speeds a bit less than 60 km/h.
I tested also the battery
again. But lipo cut off hit durng first speed pass.
I tested also one
Turnigy 2200mAh 3S 20C Lipo Pack
http://www.hobbyking.com/hobbyking/s...idproduct=8932
but cutoff was instant destiny.
The 4s seems to be too much for this system. The 2s seems to be nice steady setup. The 3s would have more fun factor and would be interesting to test. I just don't seem to have proper battery. I just ordered one of these to be tested:
Gens Ace 2200mAh 11.1V 55C
http://www.gensace.com/Gens-ace-2200...o-Battery-Pack
I was thinking also this as alternative
Turnigy nano-tech A-SPEC 2200mah 3S 65~130C Lipo Pack
http://www.hobbyking.com/hobbyking/s...dProduct=25427
but decided to test the Gens ace.
Landor is offline
Old 09-29-2012, 10:49 AM
  #1206
Rake
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Brilliant testing landor thank you for sharing.
I will try 2s 30mm prop next week. The problem for me is boat recovery !
Rake is offline
Old 10-01-2012, 09:01 AM
  #1207
carakter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
70kmh is probably way too much speed for the Bolt. This is pushing the envelope and clearly beyond the capability of the small hull.
Yes Lander, thank you for the extensive and thorough tests you performed. I learned a lot from you today!
By the way, what props are you using?
carakter is offline
Old 10-01-2012, 10:48 AM
  #1208
Landor
Landor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The propeller was always the same: metal x432. Most likely a octura copy. It says TFI 432 in it.
I sharpened and polished the propeller after the first set. This didn't change anything, my 3s battery still activated the cutoff.
The calculator
http://www.radiocontrolinfo.com/RCca...Calculator.php
Estimates 63,3 km/h with 3s. I really hope I can test this with the new battery.
- is the max speed too much
- does it generate too much heat
Landor is offline
Old 10-01-2012, 06:21 PM
  #1209
carakter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you setup right then heat won't be an issue. I really don't know how much speed the hull can reliably handle as I have not
done much in terms of testing. You on the other is the one more qualified to answer that.
How does the hull behave at those speeds? If you can do full pass runs back to back then that's a good indicator.
I am sure the water conditions play a good role in achieving those high speed runs.
I am just thankful that you are recording everything in your trial runs.
By the way, the strut height dictates how much ride height the hull is on or off the water. Move in 1mm increments and mark your reference stock point so you don't end up guessing how much you've adjusted. Keep that shaft well greased and more success in your tests!
carakter is offline
Old 10-02-2012, 08:17 AM
  #1210
Landor
Landor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I received the battery today...
Local store had them in stock...
http://www.eurorc.com/product/1361/g...o-battery-pack
... and yes ...that battery worked. There was not any cutoffs. Top speed was 67 km/h (41 mph), second best 64 km/h. At the end of 5,5 min run the speeds were 56 km/h, 56 km/h and 52 km/h just before battery was empty.
I opened the hatch and measured 42 °C from battery and 37 °C from motor.
- with water temperature about 10 °C
So this config feels very good...
- Leopard 2445 3400kv
- x432
- Turnigy Marine 60A
- Gens Ace 2200mAh 11.1V 55C
Edit: Image
I placed the battery to left side as much as possible to fight against torque twist.
The "G.730 VENTUS GPS-logger" next to battery.
Edit 2: Trying to add video
[youtube]http://www.youtube.com/watch?v=ZDbmeEYHXw8[/youtube]
HD link here
2 min 40 s more from same run
http://www.youtube.com/watch?v=g74dtrZagGk&hd=1
inthis video part the top speed was 64 km/h, this happens at 20 s and at 54 s. For example in more visual pass at 1 min 3 sec the recordedspeed is only 52 km/h.
Landor is offline
Old 10-02-2012, 07:40 PM
  #1211
carakter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice pond you have there! You should consider trying other props, even 3 blades.
Smaller diameter props are beneficial to higher kv motors.
carakter is offline
Old 10-06-2012, 07:37 AM
  #1212
Landor
Landor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I tested this 33/3 propeller with 3s
P1.4*D33/3 Propeller
http://www.hobbyking.com/hobbyking/s...Sea_Rider.html
The weather was not optimal. The propeller also broke. Perhaps too much power.
I tested 4s with this 27 mm propeller...
Prop Nylon 1.4 X 27
http://www.hobbyking.com/hobbyking/s..._1_4_X_27.html
The boat didn't get speed at all without throwing it to water. This made the boat very uncomfortable to run.
Landor is offline
Old 10-06-2012, 10:01 AM
  #1213
carakter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wouldn't trust the plastic props from HK, stick with the Octura's.
carakter is offline
Old 10-10-2012, 03:47 PM
  #1214
Basstronics
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try an X632?
Basstronics is offline
Old 04-16-2013, 06:31 AM
  #1215
carakter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys! Any of you still tinkering with your Bolts? After a loooong while, I got to run the Bolt at a new pond near me last Sunday.
I tried the EKOS 3 blade plastic prop. Good takeoff but no top end.
Good forgoofing around. Too badmyrun was cut short when the servo unglued itself.And I had 3 packs charged!
Well, now that I'm into running the Bolt again, might as well SBP my X432 and give that a spin. By the way, any of you tried tinkering with the prop ride height (strut adjustment)? Will try lowering the prop next run.
carakter is offline
Old 04-16-2013, 11:54 AM
  #1216
*delete M i k e u p delete*
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My ? is this! How much chop can the Bolt take? I figure it is a calm water boat, but i can be wrong, thanks!
*delete M i k e u p delete* is offline
Old 04-16-2013, 12:40 PM
  #1217
sundogz
sundogz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, you weren't wrong. It can handle ripples, but not swells. Anything taller than the boat (which isn't very tall) puts a damper on things. [X(]
sundogz is offline
Old 04-16-2013, 12:45 PM
  #1218
Rake
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Still here but not run it for ages !
Rake is offline
Old 04-16-2013, 01:17 PM
  #1219
sundogz
sundogz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well howdy do, neighbor! Good to see you're still out and about. I am rightly impressed that you still have your Bolt. Timeless fun, I suppose. Well, mostly fun with a little bother thrown in to keep it interesting!
sundogz is offline
Old 04-16-2013, 01:51 PM
  #1220
nickster46
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Still here as well guys! But my bolt is still sitting in it's box.
Need to buy myself some new lipo charger and I guess a couple of lipos as well...
nickster46 is offline
Old 04-16-2013, 02:01 PM
  #1221
Rake
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks sundogz, glad to hear or rad you too friend.
Still got 3 hulls but little time between day job, business venture, kids, wife etc etc.
Will no doubt find some time to sink my bolt as spectacularly as ever soon enough though !
Rake is offline
Old 04-16-2013, 06:33 PM
  #1222
sundogz
sundogz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And Nickster too! How about that. Well, old habits are hard to quit, aren't they? Good to hear you're both alive and hopefully well. Yep, you'd better get those lipos and that charger, methinks.
sundogz is offline
Old 04-17-2013, 05:54 AM
  #1223
carakter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anybody know of  a cheap 4-pole replacement motor?
carakter is offline
Old 04-17-2013, 09:07 AM
  #1224
Yura
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello guys!
I also run my Bolt last year.
Now it is spring in Russia, soon it will be possible to run again.
Last year I also bought second Bolt to play with somebody else, but still have not tried.
For the second I bought new ESC from HK. It is HK 30A simple waterproof ESC, but with reverse (!)
Want to try reversing, because it is needed sometimes.
A lot of other R/C take the time.
I had at least 2 planes, 2 quadcopters, want to try FPV and also bought R/C car. Can't imagine free time to run boats also
Yura is offline
Old 04-17-2013, 10:57 AM
  #1225
Landor
Landor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, lakes are still frozen also here in Finland. But this should change in a few weeks, actually there is already some open areas.
Thanks to opening this thread again... I also activated and ordered oneOctura X632/3 alu cnc 1/8 dog drive propeller.
Quote:
ORIGINAL: carakter
Well, I checked only what Leopard has to offer. One option could be LEOPARD 2845 KV2960 . And a cooling jacket for itLB28WCJ. Those key words should work in ebay.
Landor is offline
Reply
Display Modes
