Apparition-II Offshore Brushless RC Twin Hull
http://www.hobbycity.com/hobbycity/s...dProduct=11739
any one tried this boat yet , looks similar to the venom ekos ,
Apparition-II Offshore Brushless RC Twin Hull w/ Twin motor (800mm)
Twin hull, twin brushless 380 motors powered by two 70A watercooled ESCs driving a flex-drive and twisting two Beryllium copper props.
This boat was built for speed and is not recomended for small ponds and inexperienced drivers.
You will need two 3000mAh 3S 20C packs or greater to power this boat to its full potential.
Spec.
Length: 800mm
Width: 240mm
Height: 120mm
Weight : 4kg
Motor: 2 x 380 2881kv Watercooled Brushless Inrunner
ESC: 70A watercooled
Required.
Radio System (2ch) & Receiver
1 x 3kg standard size servo
3300mah 3S 20C Lipo or greater
Spec.
Length: 800mm
Width: 240mm
Height: 120mm
Weight : 4kg
Required.
RE: Apparition-II Offshore Brushless RC Twin Hull
Looking at the 3rd picture (see below), I would go with 2 batteries in parallel for better stability.
I think 2 of these will do, also gives you longer run time: http://www.hobbycity.com/hobbycity/s...idProduct=9465
My Feedback: (20)
ORIGINAL: plane-addict
