balancing props
balancing props
am i the only one that goes though props? I spend hours balancing and then it seems like a couple of runs later and i need to sharpen it again. I may need to find a better spot to run, cause i'm getting tired of paying 20 bucks for a prop and then working on it forever just to have it all go down the drain, i picked up a grim prop that i still need to balance out and really don't want to destroy that one cause it was close to 30 for it, here is a video
http://www.youtube.com/watch?v=93ufEkudcKA
RE: balancing props
Ya looks like where you are running might be the cause...
I was recommended by several people to use the carbon props sold at offshoreelectric as they are cheap and dont need balancing and sharpening..maybe look into those?
OH
RE: balancing props
LOL! Yeah ha ha! At the very least limit your prop to using the CF props there. Boat looks like it's running healthy. I figured you nicked it in rapids but looks like you have bigger problems. Find a new place or convert to jet. My props last indefinately unless something catastrophic happens (like in your vid) actually that's never happened to me. I know what you mean because I bought a 642 aluminum once and put the boat in the pond. I had to idle through some floating mulch and that's all it took. Boat wouldn't even plane off. CuBeTi props are much better but they don't like rocks.[:-]
RE: balancing props
i'm waiting for dragonfire to mold me some pieces for my jet at the moment. i usually try to run in a more open area but a lot of the water close by is private. it's really sweet to see it run up the stream at wot though.
RE: balancing props
i found that out, the glanced the wall, spun around and the prop hit and threw the boat, the blade curled over and is ruined now, only place for it was the bin
