If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 16 of 16 FirstFirst ... 6141516
Results 376 to 391 of 391
  1. #376
    Join Date
    Jan 2010
    Wellington, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Miss Geico 29 Catamaran
    Ran the MG for the first time today, really windy and choppy but she handled beautiful, no wah - wah or bounce (got the kintec V2 offset rudder) and managed to do my first blowover running into the wind. It was atlow speed really I just pulled the trigger off a wave into the wind and she's bottom side up.. dang! No damage at all. Using my digital thermometer (finger) I checked temps, basically cold / warm at most so all is good.
    So now the quest for more speed starts,
    If I buy a 180 amp ESC to run 5 cells. What cells to I buy ?
    Presently I'm running 4S. I havetwo Hyperion G3 7.4v(2S)35C 5400mah andtwo Thunder Power 7.4v(2S) 45C 6500mah batteries (IE a set of 4S Hyperion and another set of Thunder Power 4S)
    I presume I buy matching 3S batteries
    EG; Hyperion G3 11.1v 3S 35C 5400mah and TP 11.1v 3S 45C 6500mah and run these in series. IE: 2S pack on one side and 3S pack on other side of the boat.
    Realise this is a newb question but would like to know for sure.
    cheers,
    Gordie.
    Ultrasport brotherhood #29
  2. #377
    Join Date
    Feb 2008
    Poteau, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yep..Just put a 2s on one side and 3s on the other..Disable the bec and run a external RX pack..I like to put the RX pack on the 2s side to help balance out ride..One side will be lower in the water do to the 3s being heavier than the 2s..Put the 3s on the right side since you have the Kinteic offset and it will carve right hand turns unbelievably! With the Kinetic offset installed,It likes right hand turns better than left anyway..
    Miss Geico
  3. #378
    BACKEMF's Avatar
    Join Date
    Sep 2003
    Milton, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You better put a canopy on order now or be unhappy after your cracks. The canopies are not in stock and they will be some time!!!
    DF33Neu1521-4S,, 40\"DFcopy6S-1200Kv5694, Miss \"G\"!
  4. #379
    Join Date
    Apr 2007
    Walnut, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ordered myself up a fiberglass canopy from Tiqueman, on OSE. Should be here by the end of the week. First one he pulled from the production mold[8D].
    I cracked in inside of a sponson when I hit a buye a while back so she's in need of repair anyways. Nothing bad, just a crack along the inside seam. So I'm going to repair that and prime the whole boat white and run it that way until I come up with a new race team theme. Right now I'm leaning in towards the silver Amsoil theme. I'll take pictures of the canopy when it gets here.
    I also have an extra, brand new, 1800 kv Castle outrunner like the one that's in my Geico if anyone is intrested. It flings a x445 prop as easy as it does a x440 on 2, 2S 20c packs. I have no doubt it will spin a x447 and still be under propped. Its compatible with the stock ESC too..
  5. #380
    BACKEMF's Avatar
    Join Date
    Sep 2003
    Milton, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Those are nice motors.
    I've also ordered a canopy from Scott on OSE. You know me by Ray Schrauwen.
  6. #381
    Join Date
    Jan 2009
    , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Im trying to get one of those canopies too! My name over there is TheShaughnessy
  7. #382
    Join Date
    Jan 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Guys,
    In terms of speed upgrades, what's the best option between running 5S batteries verses a higher kV motor and retain 4S. Both would require I buy a new ESC.
    So saying I buy a Seaking 180 ESC, is there any difference betwen keeping the stock motor and running 5S, or retaining my 4S batteries and changing out the motor for say a leopard 4074 at 1774kV. It seems to me both systems would add about 20% to the prop revs.
    I think the new motor would possibly be cheaper in the long run 'cos adding 3S batteries to go with my 2S is pretty expensive.
    Is there any advantage with stock motor on 5S versesa 1800kV motor on 4S both would berunning through a 180amp ESC?.
    Also with a 180 amp ESC is it still recommended to disable the BEC when running 5S?
    Cheers,
    Gordie.
  8. #383
    Join Date
    Apr 2007
    Walnut, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gordie, if speed is what you're after, I installed a Castle 1512 2650 kn in mine. Lets just say it's not slow Look back a few pages and you will see videos of it. Expect to run 2, 4S packs in parallel though or your run times will suck. The UL1 motor is a great option but I know a few people who have had them and they don't last very long. Other than that you can get a Leopard 3674 2650 which can be found here[link]http://www.hobbypartz.com/leopard.html[/link] This way you can use a 36mm cooling sleeve as they don't make one for the Castle 2650 that is a direct fit.
    I can dumb the high RPM motor down by lowering the motor timing. At 2* of timing its about as fast as an 1800kv motor. At 22* of timing it will travel back in time, lol!
  9. #384
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    what about using a x440/3 prop with the CC1512 2650kv motor on 4s? [:-]
    first to own the Mini Slash!
    Amsoil Dealer.. 6XL Revo, Baja 5B, Losi8T, PS295, UL-1, AQ MC, OM29, DF33
  10. #385
    Join Date
    Apr 2007
    Walnut, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got the Geico wet yesterday. Threw on a 48mm Grouper carbon prop to see how it went. Went well, I think[8D]
    [link]http://www.youtube.com/watch?v=OwBj_EGu5Sc[/link]
    With new Tiqueman lid
  11. #386
    Join Date
    Aug 2004
    Grand Blanc, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just received my Miss Geico today, the thing looks awesome and I can't wait to get it into the water this weekend when we go camping. My only problem is that the ESC is programmed for only Ni-Mh and all I have is LiPo's and the program cards are all on back order. Anybody know what can happen if I run the ESC as programmed with the LiPo's, as far as I know I just have to be careful not to run the LiPo's too low?
    HPI E-Firestorm Flux
    HPI .21 Savage
    Team Associate NTC3 Plus
  12. #387
    Join Date
    Nov 2009
    Gordonsville, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Would like a little advise . I have the Geico with a seeking 60 amp ESC X642 prop and www.aircapitolhobbies.com off set rudder . Everything else is stock . If I run two 3300 MAH 3s in paralle would I have a problem or should I just stick to 2s . Thanks for any help in advance.
  13. #388
    Join Date
    Feb 2011
    mayfield hts, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hi guys anyone know the stock set up the way the hardware came rtr with the miss geico
  14. #389
    sollie's Avatar
    Join Date
    Mar 2006
    DRAMMENBuskerud, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    leo 2000 kv , 180 amp esc , 4s , 642 prop.
    [youtube]http://www.youtube.com/watch?v=6NUAaezOKeU[/youtube]
    m445 soon to come.
    Drammen Rock City
    http://norwegianrctank.weebly.com/
    Tamiya KT, Tamiya KT P Turret , Tamiya JP , 2x Tamiya Panther , Tamiya Leopard , Tamiya Pershing.
    Heng Long KV2, Heng Long Kv1 ,Heng Long Tiger ,Taigen Panther F , Taigen Jagdtiger
  15. #390
    sollie's Avatar
    Join Date
    Mar 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    On 5s and prather 215
    [youtube]http://www.youtube.com/watch?v=xMFZBMm4aTc[/youtube]
    Drammen Rock City
  16. #391
    JPriami's Avatar
    Join Date
    May 2005
    Cumberland Furnace, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Miss Geico recorded from dock. Trying to drive and film at same time
    [youtube]http://www.youtube.com/watch?v=6rpipfL3nyU[/youtube]
    Miss Geico recorded from rescue rig out on lake.
    [youtube]http://www.youtube.com/watch?v=xy446EzI_yI[/youtube]
    Land, Sea & Air, A true RC Addict
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
