If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 9 of 16 FirstFirst ... 7891011 ... LastLast
Results 201 to 225 of 391
  1. #201
    Join Date
    Feb 2008
    Poteau, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Miss Geico 29 Catamaran
    So how do you connect 2 4 cell packs in series with bullet connectors to run a 4s2p setup?
    Miss Geico
  2. #202
    Join Date
    Aug 2010
    Charlotte, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You can't! 2 4cell packs in series would be 8s
    To run 2 4cell packs for a 4s2p setup you need to run in parallel. To run parallel pack 1 + and pack 2 + both have to go to esc + pack 1 - and pack 2 - both have to go to esc -, to do this I made some adaptors out off 5.5mm bullets. The ones pictured by themselvesare not mine, but same concept except mine look like a "T" instead of the "Y" I have posted. Here is my boat with the similar adaptors. This is my pursuit 32 running a leopard 4074 2200kv on 2 4cell 3600mah packs for a 4s2p setup.
    ORIGINAL: Dirt_hawg
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1547708   Click image for larger version.
    Fast Electric Addict! I like to go fast!
  3. #203
    Join Date
    Feb 2008
    Poteau, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Diesel6401
    You can't!
    To run 2 4cell packs for a 4s2p setup you need to run in parallel. To run parallel pack 1 + and pack 2 + both have to go to esc + pack 1 - and pack 2 - both have to go to esc -, to do this I made some adaptors out off 5.5mm bullets. The ones pictured by themselvesΒ*are not mine, but same concept except mine look like a ''T'' instead of the ''Y'' I have posted. Here is my boat with the similar adaptors. This is my pursuit 32 running a leopard 4074 2200kv on 2 4cell 3600mah packs for a 4s2p setup.
    ORIGINAL: Dirt_hawg
    I know how they need to hook up..So what size bullets are you using on your batt? The actuall battery bullets?
    It would be nice to see T bullet connectors..
    Miss Geico
  4. #204
    Join Date
    Aug 2010
    Charlotte, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    5.5mm bullets. The same bullets Iuse on the motor/esc connections.
    ORIGINAL: Dirt_hawg
    You can't!
    To run 2 4cell packs for a 4s2p setup you need to run in parallel. To run parallel pack 1 + and pack 2 + both have to go to esc + pack 1 - and pack 2 - both have to go to esc -, to do this I made some adaptors out off 5.5mm bullets. The ones pictured by themselvesare not mine, but same concept except mine look like a ''T'' instead of the ''Y'' I have posted. Here is my boat with the similar adaptors. This is my pursuit 32 running a leopard 4074 2200kv on 2 4cell 3600mah packs for a 4s2p setup.
    ORIGINAL: Dirt_hawg
  5. #205
    Join Date
    Feb 2008
    Poteau, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    5.5mm bullets. The same bullets IΒ*use on the motor/esc connections.
    ORIGINAL: Dirt_hawg
    You can't!
    ORIGINAL: Dirt_hawg
    So what do you do as far as assembly...Stuff bullets with wire and then solder together?
    Thanks for all the help..
    Miss Geico
  6. #206
    Join Date
    Aug 2010
    Charlotte, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    For the adaptors I don't use wire. I just solder the 5.5s to each other. Pain in the butt
  7. #207
    Join Date
    Jan 2009
    , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i did mine like this, i should have used a little bit less wire though. It was pretty easy this way, just solder a bullet onto three wires, then connect the two matching ones to the opposite bullet at the other end, shrink wrap and that is it.
  8. #208
    Join Date
    Apr 2007
    Walnut, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The way asupervee72 is the way I would do it. I agree on using less wire though, specially when running an outrunner.
    But soldering connectors like Diesel posted would be a "cleaner" way of doing it since it doesn't add any wire. If you have a solder jig with alligator clips it should be easy to do. If not, go spend the $12 at Radioshack to get a jig, lol! Makes like a whole hell of a lot easier when soldering.
  9. #209
    Join Date
    Aug 2010
    Charlotte, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I got my jig from Harbor Freight for $6 http://www.harborfreight.com/jumbo-h...hts-65779.html. Most importantly less wire/no wire means less resistance!
    ORIGINAL: losifiend
  10. #210
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    And once again, I'm amazed at your finds D!
    I need one of these
    first to own the Mini Slash!
    Amsoil Dealer.. 6XL Revo, Baja 5B, Losi8T, PS295, UL-1, AQ MC, OM29, DF33
  11. #211
    Join Date
    Apr 2007
    Walnut, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wow, it even has a light! Baller status[:-]
    True, no wire=less resistance.
  12. #212
    Join Date
    Jan 2009
    , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    no wire means less resistance but I think they are easier to hook up, but then i never tried the other way, didn't think of that. I got my jig at harbor freight as well, made life so much easier, i actually don't mind soldering something now. Its 12 gwg wire, how bad is the resistance ?
  13. #213
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: asupervee72
    I don't think it would be that big of a deal
    you have two packs (twice the amps) going into one wire, the resistance would be unseen
  14. #214
    Join Date
    Jan 2009
    , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    that was my thought, there is just a little too much wire in the boat though, i don't like spaghetti, unless it's pasta. Just making sure i'm not wasting a ton of energy, with 4s2p there is a lot of it but I'm trying to go efficient.
    if my sentence structure, or lack there of gets out of hand and everyone is getting lost trying to figure out what the hell i'm saying let me know.
  15. #215
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    either way you do the connectors you will notice a nice constant power surge running 4s2p
    pasta and all
  16. #216
    Join Date
    Feb 2008
    Poteau, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: srt10
    pasta and all
    Power surge? Do you mean Nice constant power source? Isnt a power surge when you lose power?
    Miss Geico
  17. #217
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Dirt_hawg
    ORIGINAL: srt10
    pasta and all
    uhmmmmm....
  18. #218
    Join Date
    Apr 2007
    Walnut, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Not that the addition of a few inches of wire would create a huge heat issue but you have to take in to consideration the amperage we're asking the small gauge wire to carry, efficiently. Being an electrician, I can tell you that the wire necessary to carry a consistent 100A, would be ether #1 or #2 AWG wire, depending on insulation type and ambient temperature. In case some of you are not familiar with wire gauge, that would be wire as thick as the average pinky of a grown man. Anything smaller would create higher resistance. Resistance= heat, not voltage or amperage loss, which would associate with volume loss. Volume loss would only apply to liquid flow. Theoretically, #14 wire is only good for 15A, #12 is good for 20A, and #10 is good for 30A. I'm bringing this up just so you guys can get an idea of what were asking from these small systems in these boats, and how "just a small piece of wire" can create a difference in heat, rather than amperage flow.
  19. #219
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: losifiend
    Not that the addition of a few inches of wire would create a huge heat issue but you have to take in to consideration the amperage we're asking the small gauge wire to carry, efficiently. Being an electrician, I can tell you that the wire necessary to carry a consistent 100A, would be ether #1 or #2 AWG wire, depending on insulation type and ambient temperature. In case some of you are not familiar with wire gauge, that would be wire as thick as the average pinky of a grown man. Anything smaller would create higher resistance. Resistance= heat, not voltage or amperage loss, which would associate with volume loss. Volume loss would only apply to liquid flow. Theoretically, #14 wire is only good for 15A, #12 is good for 20A, and #10 is good for 30A. I'm bringing this up just so you guys can get an idea of what were asking from these small systems in these boats, and how ''just a small piece of wire'' can create a difference in heat, rather than amperage flow.
    bro, you are way over thinking this
    your having two wires carring the amp load that is being devided out by the two wires.. they are sharing the amp load
    it could actually have less resistance over all
    the amount of amps that are able to go through the system with a parallel connector out weighs any resistance factor period
    and take a look at the BIG FE boats who do pull 80-110amps+ constant and they are using 8-10 AWG wire [:-]
    and think of this vs. some theory
    My SV27 pulls on average 45amps cont. with 14 AWG wire on the stock esc... Fact, the 14 AWG wire works, because I get low 40's on 4s all day long
  20. #220
    Join Date
    Jan 2009
    , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    well i just did demo on a house and have 100s of feet of number one and two, maybe all three wires plus insulation is about the thinkness of my pinky but the individual wires are no thicker then 12 awg but those are solid copper. I could easily make a connector out of some of that wire but they would be super stiff. The casing on this wire says it's good up to 600v so i think it would handle the load without breaking a sweat. It does seem like the wires heat up more then i want them to. So should i make connectors using the same grade wires they use to wire up houses?
  21. #221
    Join Date
    Apr 2007
    Walnut, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Guys, I never said it didn't work because obviously it had been working for years! I just made the comment that these systems are being pushed to their limits and every bit of unnecessary wire just impedes the efficient delivery of electricity. SRT, look at pictures of true FE boat setups. The wires are as short as possible and almost look like they have some tension, they are pulled so tight. Gee, I wonder why that is? I have never seen a ratty looking fast FE setup with loads of unnecessary wire in the boat.
    asupervee72, that 600V rating is not continues. It's for bursts like like battery C ratings. You have me confused where you say you just did a demo and pulled out #2 that is no thicker than #12. But if you did it then I guess it's true.
    What I posted above was just my opinion. From there on do what works for you. Just remember that there is always a reason why electronics fail and most the time it has to to with Amperage delivery, or the lack their of. It's up to you to figure out what works. Most importantly, its to have fun!![>:]
  22. #222
    Join Date
    Feb 2008
    Poteau, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I dont care for all this mumbo jumbo..Im just going to build a connector like supervee72 keeping the wires short..If it blows up Fu(k it..Ill get a new power system..I cant stand how these conversations get like this about whos smarter than who or whos got a bigger d!(k than who...Cmon PPL There just fukn wires!
    Miss Geico
  23. #223
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    any decent 12 AWG wire from your LHS will work just fine
    fact is I use 12 and 13 AWG parallel and series connectors on my Revo that has seen 180amp spikes on 6s and my wires never ever get hot
    the motor does, but never the wires
    don't worry what others say bout this man, your setup will work just fine bro!
  24. #224
    Join Date
    Apr 2007
    Walnut, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It's funny how you guys got all worked up over 1 comment. Funny because we all claim to be here to learn and when someone says something you don't understand people pull out the "who's trying to be smarter than who" or "who's di(k is bigger than who's" comments.
    This is an open forum and everyone is entitled to their opinion. I gave mine. I never insulted anyone, or disrespected anyone ether. But whatever
    And for those with an open mind, notice the lack of excess wire in this "race" setup running 2P.
  25. #225
    Join Date
    Feb 2008
    Poteau, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nobody likes smartasses either..
    That boat looks pretty good..
    Miss Geico
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
