would this work ok?
would this work ok?
Hi all.
i have bought a brushless motor for my boat.
this is the description:
Brushless Watercooled Motor 3674 750W 2770KV For 8.4 to 12 volts. 2S to 4S lipo or 7 to 16 Nicad or NIMH packs. Mounting hole spacing of 19mm or 25mm. Diameter 46mm, length 74mm. shaft diameter 5mm. Max Amps 85.
Replacement for 700 size motors but MUCH more powerful. Use with 70 to 90 Amp speed controller.
i'm currently using 8.4V NiMh packs, but i need to get new packs. i'm also going to change the ESC because the one i've got and tried is not for a boat and i don't think it is working properly.
so my Question is?
should i use 9.6V or 12V NiMh packs? (heard that Lipo's don't like water and water gets in my boat)
And woul this sped controller work ok?
Description:
HW Brushless watercooled 90Amp Speed control (ESC) with 180 Amp burst. complete with full instructions Battery (cell): 2-6S Lipo 6-18 Cells NiMH. Size 94x33x18, Weight: 81g
here is a link to the web page of the Motor and ESC
Motor is BL3 and ESC is BL13.
Boat is 1 Metre.
here is a link to the ESC i Have now: http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
thanks Ryan
so my Question is?
Description:
Boat is 1 Metre.
thanks Ryan
RE: would this work ok?
Sorry missed link to Motor and ESC.
http://www.prestwich.ndirect.co.uk/brushless.htm
OH
How much water gets in your boat? Can you prevent it? If so get it seald up and go Lipo. I didn't do any formal calculations but that's going to be a pretty high amp setup. Those nimh's don't like that kind of drain rate.
what size lipo's would i need ?
would 11.1v 3s lipo's be ok?
also would a 40mm prop be a good idea?
thanks for the help again.
