SR71 EDF boat
SR71 EDF boat
I design and build all my boats from scratch. The boat is made from Baltic Burch plywood ,balsa ,and fiberglass I wanted to build something different with EDF's and this is what I am building .I have always liked the USAF SR71 so that is what Iwanted to build .It has twin 3400kva edf's with air rudders .
RE: SR71 EDF boat
That thing looks awesome! How did it perform on the water? I am building a edf boat right now, nothing like that but it should go.. I will post some pics when it is complete.
RE: SR71 EDF boat
Thank you The boat didnot preform well . It had so much suction it would pull water from under the boat into the intake . I was told edf have know low end power and they are right .Could not get it on plane
RE: SR71 EDF boat
Wow thats too bad sorry too hear that, nice build regardless. Are you thinking of changing anything to make it perform better, oor is it just a lost cause? I am currently building a dual edf boat, more of a flat bottom design. check it out, its called dual edf junkyard boat, in the airboat section, let me know what you think.
RE: SR71 EDF boat
ORIGINAL: ekim1940
RE: SR71 EDF boat
Sorry to hear that Ekim.
But I slapped a couple on an old boogie board rescue boat & it went OK . I added sponsons for the fast runs to make a kind of tunnel hull effect to reduce the water contact. You could give that a try.
Cheers.
Paul.
[link]http://www.youtube.com/watch?v=0o0JRuxilY0[/link]
[link]http://www.youtube.com/watch?v=iLpHQi-456c[/link]
Cheers.
Paul.
