Speed - Electric For all your electric boating needs.
Genesis Offshore Brushless RC Twin Hull (1045mm) from HK
Reply
Old 09-28-2010, 05:25 AM
NobodyFamous
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Genesis Offshore Brushless RC Twin Hull (1045mm) from HK
Mine fried on just 4s, I would not push it.  If you are going to order more LiPo's I would get them so you have more like 5000mAh
I would also get the Turnigy 120A or 180A ESC.  If I am lucky I will get mine setup and on the lake today.
NobodyFamous is offline
Old 09-28-2010, 07:21 AM
Rebel bay
Rebel bay's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you want your Genesis fast use 2x3S 5000mAh serial, good 1500kV motor and Seaking 180A esc. 2x4Sbatteries with1200kV motorwill be better but an esc working on 8S is more expensive.
An other issue is tobuild a twin setup, 4S, 5S or 6S per motor
Rebel bay is offline
Old 09-28-2010, 08:33 AM
Rebel bay
Rebel bay's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking to the price for a Castle 1512 1,5Y 1800kV, (60 US$ actually)it' s not expensive to build a twin with that setup
www.offshoreelectrics.com/proddetail.php
Too late for me I bought a set of NEU 1512 1,5Y1850kV
Old 09-28-2010, 10:37 AM
NobodyFamous
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A dual setup would be nice, but the hulls we got from HK already have holes in them and a single setup. At this point I think it is going for the most fun (read as speed) with the stock guts.
P.S.
Yours should be pretty sweet once you get that stuff setup!!!
Old 09-28-2010, 11:49 AM
Rebel bay
Rebel bay's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is only the hole for flex shaft.The mostdifficult is to find more than 10cm longstingers.I boughtpowertrims atRaceboats shop
Old 09-28-2010, 05:26 PM
  #31
Rebel bay
Rebel bay's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here' s a photo of the Genesis with NEU motors, Seaking esc' s, Raceboats powertrims, Hopf rudder, etc.
I' m satidfied this is a nice project
Old 09-28-2010, 10:30 PM
  #32
srt10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if it were me, I would do a single Castle 1520 on 5s2p
massive power and great runtimes
srt10 is offline
Old 09-29-2010, 11:18 AM
  #33
NobodyFamous
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I spent some time checking over the boat, and cleared some rough edges around the water pickup on the rudder.  I think that was preventing good water flow on my initial run.  That caused the ESC to over heat and blow.  Got the water cooling routed and the Turnigy 180A ESC installed.
I hit the water this morning, first run lasted about 8-10 minutes before I hit LVC at 3.2v/cell.  Boat ran great, and everything stayed cool, under 150F.
Second run I swapped out the prop for an "upgrade" The blue plastic turnigy ones from HK.  They look nice, but the one I used had a bad mold and I lost a blade.  Didn't hit anything, just came off from the force.  And then the vibration knocked loose the set screw on the motor collet (I think thats the term, part coupling the motor shaft to flex cable)
I need to replace the set screw as it is crap and all striped out.  I cant get it tight.  Once I find a replacement I will try making a flat spot on the motor shaft as well.  I don't want to remove the motor again as all the hardware holding it in is also crap, and the heads might strip out.
So, not great news, but only minor problems.  I need to spend some time sealing the boat a little more as it is taking on some water every run.  Once it is working great with the stock prop, I will look into getting some different metal props to try out.
Top speed today was 64.8km/h.  The boat porpoises pretty bad at top speed.  I moved the batteries all the way forward, but it didn't help much.  I think it just slowed the boat down.
I need to look into tuning with the strut and rudder.
I'll get some video and pictures next time.
Old 09-29-2010, 11:47 AM
  #34
Rebel bay
Rebel bay's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: srt10
That should be a great setup with 5S in each transom, the boat will be more stable.More weight can be an advantage with a catamaran hull and high torque motor
Old 09-29-2010, 01:43 PM
  #35
srt10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Rebel bay
Quote:
ORIGINAL: srt10
That should be a great setup with 5S in each transom, the boat will be more stable. More weight can be an advantage with a catamaran hull and high torque motor
I agree, more weight helps these hulls stay planted
srt10 is offline
Old 09-30-2010, 06:49 PM
  #36
scullyeng
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is it possible to buy this cat as a bare hull with no holes? If so how?
scullyeng is offline
Old 09-30-2010, 07:38 PM
  #37
srt10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: scullyeng
I have seen them but I have know idea where to buy them? [:-]
srt10 is offline
Old 09-30-2010, 07:58 PM
  #38
NobodyFamous
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rebel Bay pulled some kind of scam to get one, but I think it was a one time deal kind of thing.  The way it comes is ok, but the hardware (set screws) are pretty cheap.  I think the actual rudder, motor mount, stand off bracket, and other parts are pretty good.  It's just the hex key bolts and grub/set screws, they are ALL crap.  At least thats the case with mine.
Old 09-30-2010, 08:22 PM
  #39
Rebel bay
Rebel bay's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: NobodyFamous
What is "kind of scam" ??
Old 09-30-2010, 09:52 PM
  #40
scullyeng
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Rebel bay
What is ''kind of scam'' ??
Could you please share with us how you were able to purchase a bare hull.
Old 10-01-2010, 05:33 AM
  #41
NobodyFamous
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Rebel bay
I just mean, as far as any everyday hobbyist goes, they are not available. You however knew someone, or something, and some how jumped through some hoops and got one as a bare hull.
This post here
Old 10-01-2010, 08:23 AM
  #42
Rebel bay
Rebel bay's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try to contact the manufacturer
Old 10-01-2010, 03:31 PM
  #43
Rebel bay
Rebel bay's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check that link, anotherGENESIS bare hull without holes drilled for sale
forums.offshoreelectrics.com/showthread.php
Old 10-01-2010, 05:16 PM
  #44
srt10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its sold!
srt10 is offline
Old 10-03-2010, 09:42 PM
  #45
Moppie
Moppie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Rebal bay..
Thanks for sharing your work on the Genisis cat hull.
I have two of these hulls, one completely “untouched” and one from HK with the duel motor setup. I’m still not sure what to do with the virgin hull.. I am, however, concerned that it needs some serious reinforcement before I push this boat to 100 kpm.
I like your selection. By my calculation the prop rpm is around 32,000 with the noted setup.. Since you’re running two motors I would expect you would be running more toward 90 kph.
I also thought that if you are running at these speeds you need a metal prop. Forget plastic.. I’d suggest a 445 to start or in this range.
Regards,
Moppie
Moppie is offline
Old 10-04-2010, 01:45 AM
  #46
Rebel bay
Rebel bay's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Hoppie,
It' s not necessary to reinforce the Genesis, this hull is very strongly made. If you want to put carbon do it wherepowertrims and rudder areinstalled.
A PBSPassau member in Germany build a twin without reinforcing the hull.The setup is unusual:2 x Scorpion 3026 1400kV, 2 x Seaking 80A High voltage esc's and 7S battery (3S + 4S serial)
RPM unload is around 35000 :5 x 3,7 x 1850.Don' t forget that with a twin setup each propeller helps the other.The Genesis hull is very well designed like a Mystic.Perfect
[youtube]http://www.youtube.com/watch?v=xu8jH4EdFaQ[/youtube]
For a twin setup powertrims must be more than 10cm long or you can modify the hull like this
Those powertrims are designed for a twin setup Genesis but I don' t know where they are available
Old 10-04-2010, 02:31 AM
  #47
Rebel bay
Rebel bay's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
PS: Propellers choiceis limited :Octura X442 or X447; ABC propellers or HOPF/Tenshock propellers.
I' m waiting for a set of 42mmHOPFCNC Aluminium Props 3 blades, those are balanced just need to be sharpened, they aren' t ewpensive
Old 10-04-2010, 10:36 AM
  #48
NobodyFamous
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Damn thats fast!  It runs so smooth too! I need to get mine setup properly once I get a new set screw.
Old 10-04-2010, 11:30 AM
  #49
doby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: srt10
Its sold!
Yup, its mine now!
doby is offline
Old 10-04-2010, 11:36 AM
  #50
Rebel bay
Rebel bay's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Geat deal man
If you need one or two motors have a look to Castle super prices, 2 x Castle 1512 for a twin
www.castlecreations.com/promos/motor_clearance/motor_clearance.html
Reply
Display Modes
