want mono which one to get??????
want to get a mono between 35 to 40 inches. whichone should i get?
RE: want mono which one to get??????
I have a pursuit. Just slightly smaller at 32" but a great boat nonetheless.... http://kintecracing.com/Pursuit.html<div>
<div>It's running slow in this video after reviewing the eagletree data I found I had something setup wrong in my esc. I think I fixed it just have to run it again http://www.youtube.com/watch?v=QOc9vU1ltsY</div><div> </div><div>I also have this hull on the way http://www.hobbycity.com/hobbyking/s...dProduct=15235 shes gonna need some decent power though. Don't run the recommended 36mm diameter motor they suggest, that's terrible advise on their part... </div><div> </div><div>Here's the artr version once again awesome motor just a bad choice for this boat. I run the same motor in my 32" hull and this hull is a lot larger... A bigger motor would be required to get it running correctly http://www.hobbycity.com/hobbyking/s...dProduct=11892</div></div> |
