YOUR THOUGHTS ON EXHAUST!
Hi all,
i have fitted this engine thats in the link here
http://www.davesmotors.com/s.nl;jsessionid=hh6bMn2QXfzlVX7hgGLN5JZ44hjXkHwSG1 jW32X7LM9XKgJ7jhn1lMQlzDTN6FsF6hTspxqdf48k621k8hcX HH1vhBtSRgtGyrzmThGm7YJM9yKkvPmFk51QhXn22YS2!11971 28995?c=885035&n=1&it=A&id=7545
into a chinese boat and to my suprise it bolted straight in. but came across some minor hurdles.
i had to remove the carb intake funnel and could not fit the wrapped to centre tuned pipe i bought for it because they both hit the cover of the boat.
hence the cover would not close. so i bolted the origanl exhaust to it. now the only real way i will find out if it will run ok is to test it in the water i guess. but what are your thoughts do you think it will restrict the motor to much.?
worse case senario i will have to cut a hole in the lid to make room for the tuned pipe. i have put some pics of the set up and a pic of the two pipes together so you can see the differance in diameter.
RE: YOUR THOUGHTS ON EXHAUST!
Good engine upgrade but think you are going to be leaving a considerable amount of performance on the table running that factory muffler. I would not consider running a wrap to center header the best option either - usually too long to allow proper pipe tuning. Look for a 100 degree or 105 degree header - will likely not fit under the cowl but the performance improvement when running with a real tuned pipe is (for many) worth modifying your cowl a little.
I would not lose too much sleep removing the Velocity stack - it is the first thing I take off any motor I get.
One possible route is to spend the extra cash and put a quickdraw WTC pipe on it should solve the problem of cutting the hatch.
Bob.
Bob.
ON, CANADA
if there is room you could always run the pipe in the sponsen and change to a different header say one of these [link]http://www.whhonline.com/Exhaust_Systems_s/32.htm[/link]
