Speed - RC Gas Boats Discuss gas RC boats right here!
MHZ Z-drives
Reply
Old 11-01-2010, 03:31 PM
  #51
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: MHZ Z-drives
maby youy could modify you engine mounts for an extra set of iso-mounts like the mounts for Blata engines from MHZ i think they use six
rcguy1411 is offline
Old 11-02-2010, 03:41 AM
  #52
adrianojp
adrianojp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, thank you for the advice, I will keep this in mind ;-)
Probably will build a rail box out of carbon...
adrianojp is offline
Old 11-02-2010, 04:19 AM
  #53
martno1fan
martno1fan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tony at Sonic used to have some nice mounting systems for the inline zens still does and i know hes now running this engine you have so maybe have a word with him and see what he can do for you his work is awesome.
http://sonicracingaustralia.com/enginemounts.htm
martno1fan is offline
Old 11-02-2010, 04:35 AM
  #54
adrianojp
adrianojp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: martno1fan
Cheers Mate,
I saw the mounts, very nice, but not what I need for this application. I will have to build them from scratchfrom carbon plates, as I also need to keep the engine as low as possible for both CG and hatch clearance...
Old 12-08-2010, 07:59 PM
  #55
triniturbine
triniturbine's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a brand new pair of z dives installed in a 70 inch phantom with gearbox and inline whh zenoah.I am having a problem filling the drives from the bottom with the adapter kit supplied by mhz.I screwed on the fitting but when i inject the oil it only comes out of the propshaft and no oil exits the breather at the top of the drive.I see that the instructions say that the oil must exit the propshaft and then you continue filling until it exits the top of the drive.Did anyone have a similar experience i tried to keep injecting it but the force required only makes the hose slip off.I tried emailing mhz germany but i have gotten no response as yet as shirley is not well.
triniturbine is offline
Old 12-08-2010, 08:07 PM
  #56
triniturbine
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I hve a pair of z drives installed in a 70in phantom hull with an inline whh zenoah.I am having a problem filling the z rives version 111 with the oil.I have the adapter kit that I got from mhz germany but when i fill the drives with the moly lube oil the oil comes out of the propshaft as per the instructions but the problem is that i cannot get any oil to come out of the the top of the drive through the breather hole as per the instructions.Everytime i attempt to continue filling the drive with oil the hose keeps slipping off as the force required is very great.I cannot see this as normal.Did anyone have a similar experience with this .I have tried calling and emailing mhz germany to get advise on this but I have had no success as Shirley is not well.Can anyone shed some light on this problem that I seem to be having.jason
Old 12-09-2010, 06:23 PM
  #57
FlogginHarvey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: triniturbine
I had an issue with that on my S6's (same setup basically) and I completely removed the top, breather screw from the unit and went REALLY slow when filling the drive. Too much pressure too quick and POOF...oil EVERYWHERE! LOL
If you want you can also put a small zip-tie on the nipple fitting barb over the fill-hose from the siringe. That should help...but most important...take your time when filling. Going too fast makes too much pressure.
sorry to ehar about Shirley! I hope she gets better in a hurry!!!
FlogginHarvey is offline
Old 08-13-2017, 04:01 PM
  #58
JasonWalters
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default MHz drive
im
looking to run a modified zen motor and want a scale look. Direct drive with a clutch will the MHz handle that and what one.
JasonWalters is offline
Old 08-15-2017, 01:22 AM
  #59
Justaddwata
Justaddwata's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by JasonWalters View Post
im
Take a look at the NXT Drive - https://www.mhz-powerboats.com/shop/...t-z-drive?c=70 I have yet to run one though MHZ have it rated at 6hp. MHZ have long exagerated the power capabilities of the older drives (they once did a build with a pair of stern drives behind a 24hp 125cc Rotax cart motor). Though these days I think they have a better handle on what their drives are capable of. All the stern drives could handle a stock Zen and the bigger drives should all be fine with a Mod Zen. I dare say the NXT will be the ticket for you!!
Justaddwata is offline
Old 08-15-2017, 08:08 AM
  #60
triniturbine
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check out arrow shark they make some beautiful drives
