G230 G260
RE: G230 G260
Edit,
Realized that they might be aircooled RC engines. ???? G230 G260 ????
A g260rc topend will bolt right on a g230rc engine same just bigger piston and cylinder. 230 two ports and 260 four ports don't interchange.
23cc G231PUM and 26cc G260 PUM 4 bolt cylinders also interchange.
NJ
RE: G230 G260
Warehouse Hobbies sell a Super G 23cc bore up kit. It works well too.
pyro1
http://www.whhonline.com/Custom-Engines-s/53.htm
pyro1
RE: G230 G260
ORIGINAL: pyro1
pyro1
pyro1
RE: G230 G260
He did say a g230 and g260 and aircooled. Those engines are G230RC and G260rc engines and are identical except the piston and cylinder. They are both two port and share the same crankcases.
RE: G230 G260
ORIGINAL: MrMikeG
UncleCrash said nothing about ''Aircooled'' or ''G230'' or ''G260''.
What is the title of the thread ? G230 G260 LOL.
Your right, he didn't say they are air cooled, RC, PUM or ?????? two bolt or four bolt ??????
http://www.variocanada.com/products_...0RC_G260RC.pdf
RE: G230 G260
LOL. Seen plenty a RC engine in boats, you never know. They were aircooled first before Zenoah figured for $.50 we could make this thing marine and not waste time designing a marine engine. PUM's 230 and 260's are gonna be different. Crank, coils, flywheel, intake and a few other pieces are the same on those 230's and will transfer to a 260 so you would only need as $35 set of cases with the new cylinder and make the 260 or whatever you want. 36mm big bores run nicely.
