Lady Luck MHZ
RE: Lady Luck MHZ
Iran the system in other hull last fall
Not a Sneaky Pete it;s a complete new system I have been working with NXExpress to design for RCGas boats ...... takin a while to get balance right (Bottle - 3 oz, solnoid and brains with 2 9v batt inline = around 17v to sytem)
I have a pill I use and fine tune by moving hose (costme 3 engines to figure out the right size 'pill' to tune it ..last fall .lol)....... not what people think ........... it creats way more torque than it does a 'hit; ..... u can pull bigger props and once u get then 'up' just click it off
I'll do video when I can right now just me sneaking it down south once in a while on 'road trips' for work
ON, CANADA
RE: Lady Luck MHZ
Verry nice Randy one question how do you compensate from it leaning out when on the juice ? hope to see some numbers using the juice vs. no juisce to see how much gain is achived
RE: Lady Luck MHZ
I run it Fat on the high end and do a little work on the carbs
I'll post some numbers after I get some good video and then I'll run both the NO2 boats with and without ... just remember I live in Northern BC......... will not be for couple weeks yet
the 2 carbs on right seem to be working best a CC 257 and my 771
I use a velocity stack (one of many I tried) from Tough and its widen and reshaped inside .. there is 3 set slots I can move hose tip closer and it's shot in on a angle not straight or it will just bog and die .... I'll show some more later
ON, CANADA
RE: Lady Luck MHZ
thought that you would have to run rich on the high end what hp increase do you think you will get with the jet you are using now 1/2 hp 1 hp just wondering boat look s killer by the way
TN
RE: Lady Luck MHZ
Looks nice Randy.
I had pretty much given up thinking about nitrous but I definitely see a SAW application[:-]
Give just enough boost to get the bigger prop on pipe and your off.
RE: Lady Luck MHZ
ORIGINAL: Paul M
Looks nice Randy.
Looks nice Randy.
Exactly ,Paul ,,,,,,,,, some else seen the light ..... I'm just playin but that's the deal .... once u spin em up I shut it off and the egines seem to maintain the speed and rpm ..... just need a shot to push u over the edge I tried 4 diff set ups (NOS, NEX and this NXExpress) last year on 3 boats and 5 engines .... this SYSTEM works ......
My Razor pushed some props it could never spin before .........
