Exceed RC Gas Boat
GA
Exceed RC Gas Boat
Does anyone know how these things are? I have experience with 2-stroke rc buggies so I can fix it if something goes wrong.
http://www.nitrorcx.com/99b-12003-ch-1300-gs260-artr.html
RE: Exceed RC Gas Boat
ORIGINAL: rcguy1411
Save your money they aren t worth the cost of shipping
The boat they have copied (The Warehousehobbies Super G) is hard to beat in quality and company service - to save a few $$ you are surely to be disappointed and spending more in the long run.
NY
Hi
Just go buy a boat from WHH or a used WHH in the classifieds ! Trust me on that !
Yes I have one that was given to me. It's made very cheap and took a lot of work just so it could be run.
The boat pictured on web has a better radio box then the one I have and colors are different, other then that the same boat !
I have run with stock engine and prop 25 MPH on a good day. I have about 10 hours run time and it still runs !
I only put the time into this boat because my son wanted it ! I should have just bought him a WHH boat !
1 ) strings are not glassed in there were glued in. had to fix
2 ) radio box not usable.had to replaced !
3 ) hull was made very thin I had to add glass the inside bottom of the hull !
4 ) replaced all fuel lines water cooling lines !
5 ) replace radio with one that works !
6 ) replace throttle cable !
RTR it is NOT !
RTR it is NOT !
