is this prop any good
CA
RE: is this prop any good
Its an alright prop with some Mods, entry level but an all-around decent Mono prop, would Pay more than $25 S/B , but Ya More info would help on application used for .
some info.
i will bo following mods to it, take some tongue away, thinned blades, b/s after a trail run i will deceide on back cut or not.
i want to use this on my new xxx mono, mild zen with allum. 2" pipe.
then on my 41" falcon cat, std zen with a stainless quite pipe.
thanks guys.
thanks guys.
before you go choppin the guts out of it...try it standard...i use this prop on my 48 inch mono.. standard zen ...qd steel pipe...and its the best prop i have used i have used other props with less succes...using this prop solved the rear of my boat skippin in the turns..keeps my boat in a straight lins...i am not fighting the wheel..and although my boat is not the fastest it is one of the most consistant winners...so before you chop it up give it a go....bob
