Zenoah G26PUM Engine Care!! Any suggestions please!
I like to be very clean in my boat and also on the enigine ....... was using like crazy WD40 but when discussing it with my LHS he said that I’m ruining the engine cause it's corrosive!!!
I nearly run every week and in between, after cleaning the engine, i have the habit of soaking the engine in WD40!!!
Stop it without fuel, a couple of spurts in the carb at WOT and a spurt through the plug hole. I crank it a couple of times, and put it away on the shelf, ready for the next run!!
Is this good practise or not??? Is there any other worth getting products I should use, which are mild on my pockets!!??<o></o>
I use CRC silicone spray. My engine is almost 6 years old and still looks new. I never sprayed anything in the carb or cyllinder after im done using it. I always leave fuel in the tank and carb. Sometimes the boat sits for months at a time between uses and she runs perfect.
Zazza, what many nitro boaters use is Corrossion X. It's similar to WD-40 in many respects except it doesn't clean like WD-40 does. You can buy it in either an aerosol can for $16 or in a trigger spray bottle for around $9. What makes this product better still is you can use it to make your radio gear more water resistant in case of a crash that lets water into the radio box
