Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
$20 Recovery Boat
Speed - RC Gas Boats Discuss gas RC boats right here!
$20 Recovery Boat
Old 03-31-2012, 07:06 PM
The Ghost
The Ghost's Avatar
Default $20 Recovery Boat
Got some stuff from a garage sale today. A 35" mono hull and electric outboard with a 3060kv motor fitted. The motor works as I tried it out with a aero speedie. I have a couple of 5800mah hardcase 2cell LiPo's from cars that could be used. I'll pick up a cheep water cooled speedie from HobbyCity. Should work out well as a recovery boat, cheep and easy to use.
I will have to seperate the deck from the hull as it is almost falling of now anyway, and then I'll clean it out and fit out the hull, then re join the two. Should be a good boat after it's finished.
Question, Anyone know what brand the outboard is? It looks like it has done very little work as there is no wear in the drive shaft or flex drive.
Cheers
ID:	1745242   Click image for larger version
ID:	1745243   Click image for larger version
ID:	1745244   Click image for larger version
ID:	1745245   Click image for larger version
Old 03-31-2012, 10:46 PM
wetsleeves
Default RE: $20 Recovery Boat
I think its the pro boat outboard leg
Old 03-31-2012, 11:16 PM
The Ghost
The Ghost's Avatar
ORIGINAL: wetsleeves
Thanks, Now I can do a search.
Washed the hull and seperated the top, made up a radio box, speedie and battery mount plate, still have to make up the transom reinforcing plate.
Cheers
ID:	1745291   Click image for larger version
Old 04-01-2012, 02:15 PM
SS RC Boats
Let's hope the boat your recovering stays afloat....if not,dont think that retreival boat will work too good!
Oh how i love my 13' retreival boat!!!
Old 04-01-2012, 10:20 PM
The Ghost
The Ghost's Avatar
I have the floor in and the radio box setup and installed, have the motor mounted, now just to rejoin the hull and deck.
Cheers
ID:	1745795   Click image for larger version
ID:	1745796   Click image for larger version
Old 04-07-2012, 05:24 PM
The Ghost
The Ghost's Avatar
Hi All, have the gear all in and the deck joined. All setup now except for a water outlet(should be here this week) Cant use the water because of all the tourists down for the hol's. Total weight with batteries is 2.1 Kg Shauld be a good little boat.
Cheers
ID:	1747877   Click image for larger version
ID:	1747878   Click image for larger version
