RCMK steerable stern drive
RE: RCMK steerable stern drive
Better find yourself a needle-bearing that has needles the same size as the break-pin :-)
And make the square on the cable VERY light-going into the joint.
All is repairable easely , but IMHO it's not a "fool-proof" concept.
So what your basically saying Hendrix, go with the WD-200 drives for the longevity if you can afford it ?
Cheers Mick
Cheers Mick
ORIGINAL: qdemon
Hi if I were you I would forget trying to put any kind of steerable drive on a 39'' boat they are to big, i have a pair of WD200 drives on my 58'' apache ( see my pic ) drive is 6'' in length from Transom to drive dog, and you will need a lot of servo power ( more expense ).
Bob.
Bob.
