Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
New 54" Mystic Sport
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 07-26-2012, 04:28 PM
SCGoFast
Default RE: New 54
ID:	1786270   Click image for larger version
ID:	1786271   Click image for larger version
ID:	1786272   Click image for larger version
ID:	1786273   Click image for larger version
ID:	1786274   Click image for larger version
ID:	1786275   Click image for larger version
Old 07-26-2012, 04:31 PM
SCGoFast
Default RE: New 54
Thanks Randy - I think I stumbled into doing it right. The first picture is of the new rudder setup. The second one is of it from behind. the third photo is of the original setup. there is one of it on the water - no cowl.
I will try to post some of the other pictures.
Phil
Old 07-26-2012, 04:42 PM
SCGoFast
Default RE: New 54
ID:	1786277   Click image for larger version
ID:	1786278   Click image for larger version
Old 07-26-2012, 04:54 PM
SCGoFast
Default RE: New 54
I tightened up the lines so that there is no play in them now. I haven't had a chance to run it yet but I believe that will fix the problem I was having. Really looking forward to getting to run her wide open.
Question: On the Pipe, I really need to do something quick to keep it from rusting. I have a friend that does powdercoat. Will that work or what do you all recommend? I was thinking some good spray paint, maybe something for grills might work good.
Phil
Old 07-26-2012, 06:03 PM
mistycreekboats
mistycreekboats's Avatar
Default RE: New 54
Clean it good and paint with "header paint" from Auto Parts store
Clean parts first and wipe with gease remover
I use VHT and bake in old small oven outside ....... works well on small parts
don't bake it inside the house - fumes real bad   u can also bake it but running boat and letting heat up and cool down a few times ... don't touch it till it's baked either way ....
Old 07-26-2012, 06:10 PM
  #31
Johnnysplits
Default RE: New 54
SCGoFast-   could you tell me what the hull itself weighs please. I really love the look of this boat and i've been wanting to do a battery powered rig for a while now. This thing would look sweet doing a fly-by at 90+  !!
Old 07-26-2012, 06:11 PM
  #32
mistycreekboats
Default RE: New 54
Paint I use for headers/pipes
http://www.summitracing.com/search/B.../?autoview=SKU
Old 07-26-2012, 06:54 PM
  #33
SCGoFast
Default RE: New 54
Johnny - Not sure what the bare hull weighs.
Here is the contact info for the guy who makes this hull his name is Rick: [email protected]
I will settle for a sustained 70+ and a smooth ride. Should have a video up by the weekend.
Phil
Old 07-26-2012, 06:57 PM
  #34
SCGoFast
Default RE: New 54
Thanks Randy that is exactly what I am going to use.
Phil
Old 07-27-2012, 01:22 AM
  #35
Johnnysplits
Default RE: New 54
ok cool...thanks Phil
Old 07-27-2012, 01:37 PM
  #36
savagenitroflux
Default RE: New 54
ORIGINAL:
Phil
sweet, i look forward to your video. could you post a list of the hardware that you used and if possible, web links? i want to build one of these hulls and want to refer.
thank you,
freddy
Old 07-27-2012, 03:10 PM
  #37
SCGoFast
Default RE: New 54
Nitroflux - You'll want to speak with my builder Rick Jacobson at Central RC Hobbies for a list of the hardware, manufacturers and prices. The guy is top notch and will be able to give you the info on the hardware.
Link to his site: http://www.central*********.net/
E-Mail contact info: [email protected]
The Engine is from Quickdraw Engines out of California. Ask for Todd or Mitch. Those guys know what their talking about.
Link:http://quickdrawengines.com/
E-Mail contact info:[email protected]
Good Luck, Phil
Old 09-19-2012, 12:25 AM
  #38
SCGoFast
Default RE: New 54
ORIGINAL: mistycreekboats
The VHT worked GREAT Randy - Thanks!
Phil
Old 09-19-2012, 12:29 AM
  #39
SCGoFast
Default RE: New 54
A couple of videos.
Keep in mind I didn't buy this boat to race but rather just to goof off with so.....if my navigation seems a bit random that's because it is.
http://www.youtube.com/watch?v=xpcYHlEt3B4
http://www.youtube.com/watch?v=TlTt3-GASoU
Phil
Old 01-31-2013, 07:49 PM
  #40
espressoo
Default RE: New 54
Nice cat. Can you tell me the width of this boat? Is it 53" or 54" in length? Also, what's the going price? $399 + shipping or can it be had for less?
Old 01-31-2013, 09:10 PM
  #41
SCGoFast
Default RE: New 54
ORIGINAL: espressoo
Thanks - Never measured the width. The length is 53". As far as the price I believe $399 + shipping is still the going rate for a brand new one.The link to Central is in this thread. I see Rick has a used boat section now so I would check that to see if he has one for less. Rick's a good guy to call and talk to. Very knowledgable about the hobbie start to finish.
Phil
Old 01-31-2013, 09:14 PM
  #42
SCGoFast
Default RE: New 54
New video on a friends pond:
http://www.youtube.com/watch?v=4-ZQizvVjTQ
Phil
Old 02-01-2013, 04:36 AM
  #43
redlinemotors
Default RE: New 54
Most boats will pull to the right due to prop walk, not much you can do except put left trim into the rudder. Make sure there is no slack on your push pull rudder system as this will cause problems with running straight as well.
Old 02-01-2013, 05:49 AM
  #44
espressoo
Default RE: New 54
ORIGINAL: SCGoFast
Thanks - Never measured the width. The length is 53''. As far as the price I believe $399 + shipping is still the going rate for a brand new one. The link to Central is in this thread. I see Rick has a used boat section now so I would check that to see if he has one for less. Rick's a good guy to call and talk to. Very knowledgable about the hobbie start to finish.
Phil
Thanks Phil. If you have a chance, can you measure the width? I'd like to see how it compares to the Expresscraft Thunderbolt that's been around forever.
Old 02-01-2013, 04:41 PM
  #45
SCGoFast
Default RE: New 54
ORIGINAL: redlinemotors
All good advise thanks. Yea I tightened the pull cables after about the second or third run per Rick's advice and that got her running much much better at speed. Also I meet up with a guy named Tahoe from here. He lives near me and showed me how to adjust my transmitter full "left trim". After those two adjustments I haven't had any more issues with it running straight WOT.
Phil
Old 02-01-2013, 04:42 PM
  #46
SCGoFast
Default RE: New 54
ORIGINAL: espressoo
ORIGINAL: SCGoFast
Thanks - Never measured the width. The length is 53''. As far as the price I believe $399 + shipping is still the going rate for a brand new one.The link to Central is in this thread. I see Rick has a used boat section now so I would check that to see if he has one for less. Rick's a good guy to call and talk to. Very knowledgable about the hobbie start to finish.
Phil
Will do.
Phil
Old 02-01-2013, 05:08 PM
  #47
SCGoFast
Default RE: New 54
As soon as I settle on what boat I want next I'm going to give you guys a ring. Right now it's between the New 59 Outerlimits SV which I know the Redline 29 would push really nice or another 54" Mystic Sport that I'm thinking about letting Keith Bradley build for me in FE with some ridiculously over powered huge electric motor in it. Maybe even twins.
The reliable speeds I'm getting out of the Quickdraw Pioneer 29 is no doubt great. Spent this last season just getting used to driving the boat. As soon as the weather permits I am going to start making carb and prop adjustments to see if i can get her dialed in like you guys do.
For the record I haven't seen one video where a Redline engine wasn't pushing something to it's limits. Have heard nothing but good things about Redline all the way around.
Phil
