If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 23 of 23
  1. #1
    Join Date
    Oct 2010
    Preston, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RCM and MHZ Z Drives
    I already have a RCMZ drive and im looking for another RCM Z drive if anyone has one.I have cash waiting.
    I have been offered an MHZ Z drive that looks exactly the same as my RCM but are they internally?
    Is the RCM Geared up 16%????
    With thanks
    Jack
    MillPond Models
  2. #2
    Join Date
    Nov 2008
    hamilton, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RCM and MHZ Z Drives
    Not shure if they are geared the same i know there harder to find as they are not made anylonger i have a couple of the mhz z drives if you dont end up getting the mhz drive i may be interestedin it thanks
  3. #3
    Join Date
    Oct 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How do you get the Z drive apart!!!!
    MillPond Models
  4. #4
    Moderator Justaddwata's Avatar
    Join Date
    Feb 2005
    RI-USA, RI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the RCM is a 1.16:1 ratio - same as the MHZ
    One of the better gas boat picture sites - http://imageevent.com/justaddwata
  5. #5
    Join Date
    Nov 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Jackal1983
    There is a small set screw on the top of drive remove it then i use a small screwdriver to slide the bearing out this will alow you to get to the front bolt holding the lower unit i will be pulling one apart his week ill take some pics
  6. #6
    Join Date
    Oct 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That would be great rcguy!!! What loctite are you using to glue the shafts into place?
    I think I might buy the MHz on and put it on the back with my rmck one. Give them both a lick of paint!
    Cheers guys
    Jack
    MillPond Models
  7. #7
    Join Date
    Feb 2005
    RI-USA, RI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The MHZ drive should have a square input and so not need loctite. The RCM drive use Loctite 648 retaining compound for the flex cable/input gear.
  8. #8
    Join Date
    Nov 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here are a few pics of the drive apart
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1798210   Click image for larger version.
ID:	1798211   Click image for larger version.
  9. #9
    Join Date
    Nov 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Few more
ID:	1798213   Click image for larger version.
ID:	1798214   Click image for larger version.
ID:	1798215   Click image for larger version.
  10. #10
    Join Date
    Nov 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Not shure why that one pic keeps hetting turned upside down hope they help
  11. #11
    Join Date
    Oct 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thankyou very much rcguy.
    just a quick question does the imput shaft come out fairly easy?
    MillPond Models
  12. #12
    Join Date
    Nov 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Once you remove the setscrew i use a small flat screwdriver to gently work the bearing out it comes out fairly easy just be carefull i want to make a tool that will spread apart that i can place in the flexshaft retainer so i can just pull the assembly out i have not tried to remove the output shaft im not shure how its held in if its a press fit or threaded ihave an S6 drive i want to pull apart as well but have not pulled one apart as of yet post pics of your build im going to put my drives on a Expresscraft 60" MTI using rear exhaust RCMK K30 s from holding he drives upto the boat it going to look sweet hope to get in the 60mph range anything above will just be iceing on the cake
  13. #13
    Join Date
    Oct 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yep once i get everything together i'll do a build thread!!!
    Thanks again for your help!
    MillPond Models
  14. #14
    hellya's Avatar
    Join Date
    Feb 2005
    Bonney Lake, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    here we go brand new on the market..... just snagged up one for $500
  15. #15
    Join Date
    Dec 2011
    Porto Sant\'elpidio, ITALY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: hellya
    Where did you get it? is about a year that Arrowshark shows them as ""Sold Out"" Look here http://www.arrowshark.com/scale-drive.php
    Anyway, i'll take the mhz Alu-plain that is pretty similar
  16. #16
    Join Date
    Oct 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Managed to get my self a MHz complete. I also got a complete MHz upper section and gears do I can change my rcmk one to look like a MHz with square input drives!!!
    MillPond Models
  17. #17
    hellya's Avatar
    Join Date
    Feb 2005
    Bonney Lake, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Mario Giordano
    Where did you get it? is about a year that Arrowshark shows them as ''''Sold Out''''Â* Look here http://www.arrowshark.com/scale-drive.php
    look on that website.... they have one with small blemishes for $399
    Ya....mhz usa doesnt keep any of these drives in stock...I wonder why not??
  18. #18
    martno1fan's Avatar
    Join Date
    Jan 2005
    blackpool, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have the Arrowshark outrdrive going on one of my hulls also got a spare set of gears, got the whole setup for £250 its only been used twice lol.
    Mart
    Waveridermouldings,Manufacturer of quality race proven Hulls.
  19. #19
    Join Date
    Dec 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, they have only one and is defective, so goodbye arrowshark
    About mhz Usa,be careful, do not buy from them, Shirley told me that Mhz Usa does not work anymore, more than a year, they are not able to delivery MHZ parts anymore, if you want them you will have to take it in Germany, but no problem, they ship worldwide.
    Regards
  20. #20
    hellya's Avatar
    Join Date
    Feb 2005
    Bonney Lake, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    About mhz Usa,be careful, do not buy from them, Shirley told me that Mhz UsaÂ*does not work anymore, more than a year,Â*they are not able to delivery MHZ parts anymore, if you want them you will have to take it in Germany, but no problem, they ship worldwide.
    Regards
    Did you look on ebay... 2 arrowsharks units on there for $525 each
    Ich spreakin ze deutch....
  21. #21
    Join Date
    Nov 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    MHZ USA is no longer up and running if you nees anthing MHZ germany is t he to go place great service fast shipping
  22. #22
    hellya's Avatar
    Join Date
    Feb 2005
    Bonney Lake, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    wow something happened ...the 2 drives on ebay, the auction was pulled.....contacted the seller hes like "we dont make those anymore"...hahahaha
  23. #23
    Join Date
    Dec 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I told you so, in their web page appears as ""Sold Out""
    Forget about arrowshark, go with mhz, also cheaper, 525 U$S = 408€ !!  mhz z-drive alu-plain =280€[8D]
    Regards
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
