Help on hull and motor
RE: Help on hull and motor
Hull looks like the 57" Aeromarine Sigmature - http://www.aeromarinerc.com/index.ph...d=19&Itemid=53
Motor looks like a 23cc Zenoah
Hull/Brand is a good one (though surprisingly unpopular design). Believe it is just a styling thing that has kept it from being more widely used. The Aeromarine 56" apache is probably 100 times more common/popular. I have never run one but good buddy purchased one - though dont believe he ever built it either. Looks like a nice paint scheme on yours. Hardware is a little on the rough side (looks like it is Aeromarine Hardware also) and Aeromarine hardware is overdue an update in styling. All looks in reasonable order though - for a free boat it is a keeper!!
Motor capacity is just me hazarding a guess. Looks like the older 2 port 23cc zenoah. I believe the 26cc version was only available as a 4 port. Either way it is still a decent motor and should move that hull to around 35-40mph without a lot of fine tuning. In the right hands it may well go faster. 35mph is a very respectable speed from a boat that size and would certainly be plenty of fun in a little choppy water!
Thanks so much. I know not to swim. Have a little boat that got stuck. Bought fishing pole. Works well. One more question so I can finish putting it together. There's a red and black wire off the engine. Red is hooked up but black isn't. Where do I put that wire? Is that a ground for a kill switch? I don't see a switch anywhere. Thanks for all the help
Be sure you can access the boat anywhere on the pond with that fishing pole!! this is nearing the time of year when people die in ponds
Black is for optional kill switch 90% of RC gas boats dont use a kill switch. Majority just set the radio so throttle down will stall the motor.
If you post some more/clear pics of the motor setup we might be able to point out any other things you may want to address
WA
That is Areo marine hardware
I think thats the boat pictured on his web site.
I'd guess thats a 26cc Zen
Call Remy he's great with helping out new guys
i've got his thunderboat.
tap
tap
Sorry about the size. I will post more later when I get home. Gonna replace all water and fuel lines. Don't want to chance it
ORIGINAL: Chrdec
There is also an electric fuel pump in it. 12v I believe. Do I need that? It's not hooked up to anything
