If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 8 of 8
  1. #1
    Join Date
    Sep 2002
    Copenhagen, DENMARK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    China boat exhaust o-rings
    Hi Guys.
    Have you seen anywhere that I can order som high temp silicone o-rings.
    The size is 29mm x 4.5mm ?
    Some seaweed blocked one of the cooling inlets, and burnt my exhaust o-rings.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1807503   Click image for larger version.
ID:	1807504   Click image for larger version.
ID:	1807505   Click image for larger version.
ID:	1807506   Click image for larger version.
ID:	1807508   Click image for larger version.
ID:	1807509   Click image for larger version.
ID:	1807510   Click image for larger version.
ID:	1807511   Click image for larger version.
ID:	1807513   Click image for larger version.
    Sonnich Johannesen
  2. #2
    Join Date
    Apr 2007
    Cape Town, , SOUTH AFRICA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  3. #3
    The Ghost's Avatar
    Join Date
    Mar 2004
    UlladullaNSW, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: China boat exhaust o-rings
    They are not thick enough(section) I have tried to find them, I just replaced the pipe.
    Cheers
    Remember, Always look after the ORGANIC part of the model
  4. #4
    Join Date
    Sep 2002
    Copenhagen, DENMARK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thansk Hesco, I have actualy tried those , as a friend had some in stock, and they allmost fit, but not quite.
    The pipe included does the job, and does not sound too bad/loaud. It would be a shame to replace it just because of the o-rings [:@]
    Sonnich Johannesen
  5. #5
    HendricX's Avatar
    Join Date
    Jan 2009
    Rotterdam - NL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I doubt that they are 4,5mm thick .. that will mean the inside is 20mm.
    As the manifold is 22m / 7/8" on the outside .. the O-ring will be 22 x 3,5mm (or 22 x 29) .
    Write me a PM with your shipping address.
  6. #6
    Join Date
    Sep 2002
    Copenhagen, DENMARK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Hendrix.
    The inner diameter is 20.8mm
    thickness is 4.4mm
    outer is 29.6 mm
    I have tried 3.5 mm o-rings, and they are too small.
    Sonnich Johannesen
  7. #7
    The Ghost's Avatar
    Join Date
    Mar 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: HendricX
    As the manifold is 22m / 7/8'' on the outside .. the O-ring will be 22 x 3,5mm (or 22 x 29) .
    The "O" rings are 4.4-4.5mm thick, found one while looking for something else. The "O" rings shown are a Hanson Viton, A China one(used), and a normal green one. The size difference can be seen.
    Cheers
ID:	1808532   Click image for larger version.
  8. #8
    martno1fan's Avatar
    Join Date
    Jan 2005
    blackpool, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ive had similar issues before as i couldnt find o rings to fit i wrapped the header with some thin alloy cut from a beer can,it worked fine and no more leaks.
    Mart
    Waveridermouldings,Manufacturer of quality race proven Hulls.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
