Pro Boats 1/8 Gas Llumar
IN
Can someone tell me if the stock exhaust manifold (PRB2556) that came with the 1/8 Llumar Hydro, is the same manifold that was supplied with the Pro Boats 1/8 Miss Budweiser Hydro? The parts list for the Miss Budweiser shows PRB2260 as the part number for manifold, but I know that Pro Boats did use the same part on different boats, and changed some part numbers....
Reason I ask is that all of my searches for the stock manifold for the Miss Budweiser have been futile, so I'm really hoping one of the pros here will know the answer.
Thank you very much....
Jim
Jim
CA
RE: Pro Boats 1/8 Gas Llumar
If you do a search on the boat you will see some just install a 7/8 wrap to center header and do a little dremmel work on the hatch,as it will pop out a bit. If you do a search you will see some examples,and it comes out really nice looking . As far as same header between the boats ,I believe they are same but not 100 sure .With the aftermarket wrap to center ,it will flow much better as well. The stock header has a 90 angle and effects the performance a bit.
CA
Also just a side note ,If you go to expresscraft rc boats site .Thaty carry a brand that will be quite affordable .I think around 13.00 for header.
