Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
T-bar with oil reservoir
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 01-27-2013, 04:47 AM
neverthought
Default T-bar with oil reservoir
Has anyone out there used these? what type of oil should i use? how do i retain it so it dosent empty so fast dow the stuffing tube?
Old 01-27-2013, 06:23 AM
Jackal1983
Default RE: T-bar with oil reservoir
I use them on all my boats....I use a sticky chainsaw oil... So it sticks to the shaft.... It's fairly light also so does move down easily.
the oil reservoirs have a pin hole in the so it only drip feeds the shaft.
i also think its a performance gain because the shaft is easier to to spin in oil rather than grease!!!
Jack
Old 01-27-2013, 06:30 AM
qdemon
Hi I dont use the res on top of the T- Bar because they dont come with a turn off valve so they will continue to drain oil into the shaft ( depends on how much oil you fill it with ).
I perfer to use a seperate tank and pump my own, as for oil I use ordinary 20W40 car engine oil has always worked fin for me.
Pcture is of my system on my 58" K600 Apache.
Bob.
Old 01-27-2013, 06:51 AM
Jackal1983
Very nice set up bob.... I run a system like that on my f1. I can also pump it in.. Never had a tap on it tho.
Old 01-27-2013, 12:01 PM
c.k.y.
c.k.y.'s Avatar
I'm using the 30c.c. drain pot
Old 01-27-2013, 12:12 PM
c.k.y.
c.k.y.'s Avatar
ORIGINAL: neverthought
I'm using the 30c.c. drain pot .
ID:	1844958   Click image for larger version
ID:	1844959   Click image for larger version
Old 01-27-2013, 01:49 PM
The Ghost
The Ghost's Avatar
ORIGINAL: qdemon
Pcture is of my system on my 58'' K600 Apache.
Bob.
I use the same system.
Cheers
Old 01-27-2013, 06:17 PM
HendricX
HendricX's Avatar
ORIGINAL: qdemon
Has for oil I use ordinary 20W40 car engine oil
Bob .. the pond owner will hate you for that ;-)
Not quite enviromental friendly ... better use a bio-degradable chainsaw oil ,
but cheap (sunflower) cooking-oil will also do the trick
Old 01-27-2013, 08:39 PM
Ron Olson
Ron Olson's Avatar
When I ran outboards, K&B recommended 20 w 50 racing oil and STP with a 50/50 mix. It seemed to work well for them so I don't see why it wouldn't work in your case.
Old 01-28-2013, 02:36 AM
martno1fan
martno1fan's Avatar
I use sunflower oil works great and i use the t bars that have a built in oil reservoir not a cup,i also use a teflon liner,makes for a snug fit and doesnt seem to allow too much oil to escape even when sat still.I may add an oil cup if i intend running all day and didnt want to refill the t bar but so far for an hrs running it seems fine.Like someone said make sure the holes not too big or the oil would run too fast.
Mart
Old 01-28-2013, 10:21 AM
qdemon
Hi hendrix
it really does not matter in my case running 20W50 engine oil as the water does not go anywhere its a disused china clay pit on private land which is already contaminated with all kinds of mineral deposits, I should point out that I run a very minimal amount of oil hense the reason I dont use a constant flow system in any of my boats !.
Bob.
Old 01-29-2013, 07:30 PM
neverthought
Thanks to everyone for your input, all good information. The STP mix and chaine saw chaine oil sounds like the way to go... Now I need to find this in a biodegradable version. I'm thinking, what if I mix Crisco shortening and oil?
