AC S45 Project "Stutter" Rat Finks "Brother"
Talked with Andy for a while about a new project and picked this upthe other day awesome work AC very cool very high quality
S45 Pearl White with Red Metalflake Stripe - black interior and carbon fiber transom
Cheers
Randy
Cheers
Randy
RE: AC S45 Project
Well managed to squeeze enough together for a 'starter' motor for the S45
Zen Case - K30 (cleaned up ) - mod crank / 36mm piston - matched case - CC bearings / seals / zero drags - My 771 w/ SS batwing - Zen ignition
Maston mounts - carb arm - needle clamp case and cylinder are calipher paint - baked on
It's a start
Cheers
Randy
It's a start
Cheers
Randy
RE: AC S45 Project
Managed to get some fitting done Will pull and polish or ? hardware
Waiting for HiTec 5646 Waterproof Servo yet and few small things
Oil Tank will be mounted on small piece of CF
Exposed Servo's (Hi Tec WP's)
RB T bar -
5/16" tube will be covered in shrink sleeve so it's black
Small box on side for batt + electronics
Trying to keep weigh to minimum.
""Nothing is tight or set just sitting these so I can do COG and S/S balances
RB T bar -
