Check ur Timing for $5.00 Home Made Tools
Tools need to check ur timing
Piston Stop and degree wheel
Imake a piston stop from bicycle brake ajuster nut bolt (3.00 at bike shop -has proper M10 x 1.0 threads and is alum) - drill it out - install 1/4" x 2 1/2" nylon bolt and thinned nut (39 cents) on piston side and wa la - a ajustable stop for checking timing (NOTFORREMOVINGFLYWHEELJUSTFORTIMING)
U can also drill fitting out - install set screw in side of fitting and use as a dial indicator holder
The degree wheel is a free download
http://www.tavia.com/free_degree_wheel.html
I print it - spray back with glue and stick on 1/4" [plywood and cut out center bolt is M^
as below is Daniels video on timing
http://youtu.be/A2S2K2IHZ-w
Randy
Post your Home Made Tools
Randy
