Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
Outerlimits 70 inch DV build
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 04-06-2014, 05:42 PM
Alexanderd
Default Outerlimits 70 inch DV build
Starting a new build a Outerlimits DV it will be powered by a RCMK inline thru a spitter gearbox with outward counter rotating wheels
Old 04-06-2014, 06:15 PM
Redstar1275
I like the Howard Hughes looking canopy, sweet boat.
Old 04-07-2014, 02:20 AM
mickieb49
Nice hull, is that a CRC hull?
Old 04-07-2014, 09:38 AM
Alexanderd
Yeah Mike it's a CRC Hull Ill be working on getting it ready for next month just waiting on running gear and some odds and ends
ID:	1984983   Click image for larger version
Old 04-07-2014, 10:42 AM
SS RC Boats
Get that bad boy ready for the end of this month Alex. Our next race is scheduled for the 27th...i'm sure you and Gavin can have it together by than.
Old 04-07-2014, 10:49 AM
Alexanderd
Just waiting for the Mailman LOL
Old 04-08-2014, 09:49 PM
Alexanderd
I've started to work on bottom filled in vents and will be lengthening the strakes and cutting a ride pad in bottom next
ID:	1985414   Click image for larger version
ID:	1985415   Click image for larger version
Old 04-09-2014, 12:41 AM
martno1fan
martno1fan's Avatar
Is it me or do those strakes look wonky,they just dont look straight ?.
Old 04-09-2014, 01:56 AM
Alexanderd
Shadow maybe
Old 04-09-2014, 05:33 AM
SS RC Boats
If I'm correct doesn't ride pad tend to want to lift transom of boat out of water which will kind of make bow run more wet? If so that hull definitely doest need transom lift with extra weight of inline motor mounted in there. Jrod and Hoovy1 had an issues with Pro Painters hull like that with the twins in there,they were trying to get more bow lift not less and a ride pad was not the solution. BUT I may be wrong...correct me if I am please?
Old 04-09-2014, 06:08 AM
Alexanderd
From what lance has told me the Hull mods made a big difference in the end with handling and speed
finish weight was near 34 pounds and the bottom just couldn't handle that type of weight performance wise
as for the ride pad I'm going to do this later so I can compare handling without it and with it
Old 04-09-2014, 06:14 AM
martno1fan
martno1fan's Avatar
YOU ARE SPOT ON,fact is should have bought to orriginal GTX it runs like a champ .I def do not think im seeing shadows those strakes are def not right they dont even look sharp.All adding a ride pad has done is create lift right at the transom which is the last thing you need if the boats allready running wet.Actually filling in those steps has done little if anything to changing how she will ride,they arent even real steps they are just relief cuts not real steps anyway.
Mart
def need to straighten these out
Name:	wonky strakes.jpg
Old 04-09-2014, 06:34 AM
SS RC Boats
I can see longer strakes making a difference but i definitely don't see ride pad working.
Old 04-09-2014, 06:36 AM
Alexanderd
Mart
I can only go by what I was told the hulls bottom was modifed after the fact and the mods made a big difference that's all I'm after
as for the ride stakes they aren't that sharp no and I was thinking about rectifying these
Old 04-09-2014, 08:16 AM
martno1fan
martno1fan's Avatar
Sharpening and straightening those strakes would make a big difference,i would def not add a ride pad though.The strakes are what gives the boat lift where it needs it but on that hull they could do with going much further back,i would lengthen the outer ones especially so you get more lift but not as much as a ride pad will give.If you do that i think the boat will run better in my opinion.
Mart
Old 04-09-2014, 05:35 PM
Centralrchobbies
My Feedback: (7)
Lol....those strikes are very straight you can tell they have been sanded on were it has be filled so yes does looks wonky as you say. Yes not super sharp though
Old 04-10-2014, 12:08 AM
martno1fan
martno1fan's Avatar
Thats what i said they are not straight ,as anyone can see from the pics.Maybe i should have said theyre not straight anymore ,i wasnt implying they came like that.
He has modded the bottom and obviously sanded the strakes by mistake when doing it.As for the ride pad this is not the right way to go in my opinion.
I would lengthen the outer strakes to 3" from transom,inner ones might be ok as they are but id lengthen those also to roughly where the orriginal outer ones are now.
This is what i would do anyway.
Mart
Old 04-10-2014, 03:12 AM
Centralrchobbies
My Feedback: (7)
Lance did a great job with Pro painters boat as I was able to drive it. I think the problem was lack of prop selection as it would quickly get to speed and fall off. I wish abc would make the right hand rotation chopper props which I was told was going to be in the works but that was over a year ago
Old 04-10-2014, 01:21 PM
stevo7896
Definitely lengthen the strakes back. I have the same setup you are building and went thru the same steps. Filled the vents and so forth. You will enjoy the boat. It is right at home in the chop and handles great . Mine sounds like a jetski when I do a drive by with the slapping of the water .I did my build right after propainters build and used their info as feedback .Just remember they were running dual motors .We are running inlines with a splitter so just a bit diff weight possibly. Never weighed mine to check. I will keep an eye on this build .
Old 04-10-2014, 04:13 PM
Alexanderd
stevo7896 the concept from the beginning was to build a large Deep Vee using a inline motor and spitter gearbox to race in offshore conditions that we race in here in Bermuda my thinking was that a inline swinging a large wheel would induce a hell of a torque roll in the conditions the hull will be used in I was picturing in my mind numerous course corrections the sec hull leaves the top of a wave and lands with the single large wheel at the back . At no point was top end fast factored in this as I said before I was aiming for a high powered hull to dominate in the rough stuff and with counter rotating wheels the handling should be much better than a giant wheel swinging off the back of the back end
Old 04-10-2014, 04:51 PM
Alexanderd
Filled hull deck joint and just got to do final sanding of bottom still waiting on the postman for my gadgets
ID:	1985839   Click image for larger version
Old 04-10-2014, 10:01 PM
martno1fan
martno1fan's Avatar
My thinking about what your saying about better handling with twin props on a model boat is that you will find it difficult especially in rough water.When the boat gets bounced arround on the open sea one or the other prop will unload and you could get some very nasty handling issues,way worse than overcoming any prop walk from spinning a single large prop,just my opinion mind.
On another note a friend Bob runs one of my Apache 58s with a splitter gearbox powered by a k600 she ran 72 mph outward rotation (better handling) 6717/3 props but this wasnt on the sea.
Old 04-10-2014, 10:20 PM
Alexanderd
You might just be right but as I'm not one for normalcy I like doing things outside the box and I base my theory on 1 you just don't see any large Deep Vee's running single Iline motors running decent 2 with two smaller wheels counter rotating they just might be what's needed for a good handling boat even in the rough stuff
But we'll see
Old 04-10-2014, 11:20 PM
stevo7896
I've run mine in a very large lake (Huntington Lake) that has a good head wind coming off the Sierra Nevada Mountains. Elevation is about 7000 feet and they hold regattas their yearly. It is very similar to big water running. The hull does great with this setup and the question of torque roll hasn't caused course direction changes. At idle you can rev it and cause it to rock back n forth ,but at speed haven't noticed any issues. Also I did experiment with inward rotation and it ran like crap. As Martin mentioned ,outward is the way to go . It was literally like two different boats. In regards to props unloading while the other grabs and causing handling issues .haven't experienced it .Maybe due to the weight and length of the hull.
Old 04-11-2014, 12:03 AM
martno1fan
martno1fan's Avatar
Your right not many doing the twin drive thing especially racing,you can but try.
Steve good to hear you have no issues,you might be right about the extra length,i plan on stretching my Apache to 70,might need to try the twin drives.
Only guy who has ran my Apache with twin drives in the sea that i know of is running twin electric,smaller props though and closer together than we can with gas.
As regards prop rotation Bob tried inwards and i told him it would handle like crap and it did,he changed to out and now she runs great.
Mart
