Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
Lauterbach build.......
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 11-28-2015, 04:50 AM
  #151
wdgreen
Originally Posted by zen40
Just wondering if anyone on here knows where I can get external Spring coils for supporting the water cooling fees tubes from the rudder to the transom, I have seen them somewhere but can't recall where. I think they look pretty good and add shape and support to the pickup lines.
thanks in advance.
Using the large size waterlines won't be a problem. I usually just tie the two lines together with some double sided velcro.
Old 11-28-2015, 04:53 AM
  #152
wdgreen
For those that have built and drive these hulls I'm setting up the radio gear and wonder what settings work well or best on the rudder, like in end point adjustment, speed of servo and expo.
thanks.
No expo, max speed, lots of right rudder, only enough left for straightaway corrections without flipping. Too much left will cause the boat to flip easily. Never let off the throttle while using left rudder, the boat will flip instantly. Drive it then adjust the rudder for your driving.
Old 11-28-2015, 05:30 PM
  #153
zen40
Cheers Wd, just went to start the engine for first time today with tank install done, radio setup etc,
frustrating NO spark at all, tried a couple of plugs, nothing, the only mod I've done is top mount for coil and it is self earthing to the mount with a brass tag. Disconnected kill switch so just red wire fron cool to mag connected and still no spark, brand New engine, any ideas?
Old 11-28-2015, 08:01 PM
  #154
zen40
Sorted, two dud plugs, good Ol champion, not my choice so swapped out with NGK ran a tank full through her and dialled in the needles to get her pretty close.
Old 11-28-2015, 09:09 PM
  #155
zen40
Slowly getting the stand sorted, built to transport and run up on, also built a add on for display to tilt the boat, I've got some laminated side panels to go on when I get them second coated in clear.
Old 11-29-2015, 05:25 AM
  #156
wdgreen
Glad you got the engine running. We toss out the champion plugs that come with the Zens. They have been known to come apart and ruin an engine. Always use NGK.
Hard to set the needles on a stand with no load. If you have a 257 carb then set the high at 1 turn out and the low at 2 turns out. This is usually pretty close to right on.
Old 12-26-2015, 01:10 AM
  #157
zen40
Howdy, I'm after a few option for prop recommendations got the lauterbach, running a standard Z26cc on alloy tuned pipe, I've got a AS 67 17 3 but would like a couple more options maybe a 2 blade as well, cheers
Old 12-26-2015, 05:58 AM
  #158
wdgreen
Best prop you can run is a 6717/3 400 from Propworks west. Tried everything else.
Same set-up as yours.
Old 12-26-2015, 11:33 AM
  #159
zen40
Cheers
Old 03-06-2016, 02:21 PM
  #160
zen40
Weekend just gone and finally ran CRC. Was a thrill to have PG Knight, Peter Senior and Andy Knight present at the launch at Lake Rotoiti where so much of New Zealand's powerboat race history was made.
a short and unfortunately no so good quality video of the first run of this model.
All n all a great success with the oat running very well, a couple of minor adjustments to the pipe setup and it will be sorted.
the crowd at the 17th annual classic and antique boat show were very appreciative of the work gone into CRC.
when I get some better video I'll also upload it.
Old 03-06-2016, 02:22 PM
  #161
zen40
Here's the link to the video.
http://youtu.be/t1bJEs6FOGw
Old 03-06-2016, 02:34 PM
  #162
cmsrp
Great job zen. Love it !!!!
Old 03-09-2016, 10:26 PM
  #163
zen40
Thanks very much.
Old 03-28-2016, 05:18 AM
  #164
corky051
Great job Zen!! Glad to see this effort a major success. Looks great on the water. Congratulations!
Old 03-30-2016, 02:30 AM
  #165
zen40
I've been making a few adjustments after the first few runs and sorting a couple of issues the bugged me. I've built on a water pick up on the back of the rudder to supply better cooling to the engine and pipe, the stock rudder pick ups struggled in long turns to supply sufficient constant flow.
ive also re-mounted the pipe bracket and used high temp silicone as the stock rubber grommet melted on first run. The silicone header cooling sleeve works a treat and really cuts down on a whole lot of intense heat, it has proved to be 100% leak free on testing.
I also shimmed the rudder piviots to get rid of what I thought was excessive slop and have the rudder with near on zero play while still allowing smooth range of movement.
Ive replaced the standard pull start with an ezzy pull starter which is sooo much better.
Im still mucking round with a windscreen setup and this is proving to be slightly frustrating as to what mounting choices I have, I really want a tinted screen but want to get it right.
A couple of other things are the lifting eyes they used for crane launching and the rear spoiler that was used on the full size,
My good lady is about to make a cover up for it as well.
really keen to get hrr back out on the water and get a few laps on her.
ID:	2155090   Click image for larger version
ID:	2155091   Click image for larger version
ID:	2155092   Click image for larger version
ID:	2155093   Click image for larger version
