Speed - RC Gas Boats Discuss gas RC boats right here!
Battery for gas boat electronics.
Reply
Old 05-16-2014, 08:02 AM
zen3
zen3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Battery for gas boat electronics.
I have been using 4 double A energizer batteries in a battery pack to power my 2 large non digital scale servos. 1 throttle standard servo, and rx. Needless to say the batteries drain quickly and it's expensive. I have 9.6v 1600mah and 700mah nimh. And also 7.4v nicad batteries at 1800 mah. And 8.4v nicad batteries at 3000mah. Can any of these power my electronics safely.
zen3 is offline
Old 05-16-2014, 03:15 PM
Ron Olson
Ron Olson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You're safer with the 7.4 volt packs. I've tried 9-volts but I really don't recommend them. Most boaters are only using 6-volt packs, 5-cells if you will.
Ron Olson is offline
Old 05-16-2014, 04:42 PM
zen3
zen3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Ron. Have a bunch of them from my kids traxxas cars. They switched to lipo and brushless. So I have all these practically new nicads around. Wasn't sure if you could only use 6v. The weight of the pack up front will do my tunnel balancing good. Thanks.
zen3 is offline
Old 05-16-2014, 06:12 PM
danielplace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
None of those are suitable for receiver/servo use unless you have HV lipo rated servo's of which your analogue servos almost certainly are not. You will need a regulator which is a waste of time and money and more electronics is not what you want in a boat.
Get a Life 2S 6.6 volt pack of 1300 mah to 1800 mah. Plug right in and work with almost all servos.
danielplace is offline
Old 05-16-2014, 07:05 PM
BMAD01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree with Daniel. I switched over to the 1300mah Life packs he suggested and will never go back to NIMH batts. In fact I bought mine from him. They hold a charge forever. I run a volt meter in my radio box's and they never seem to get below 6.45V! I balance charge them maybe once every 3 weeks out of guilt mostly. Brian
BMAD01 is offline
Old 05-17-2014, 04:37 PM
idocdave09
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you work up a 5 cell pack of NIMH that will work also I use 3000 ma and they last a long time for me.
Dave
idocdave09 is offline
Old 05-17-2014, 05:33 PM
zen3
zen3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave
I could do that I guess.
zen3 is offline
Old 05-18-2014, 04:07 AM
danielplace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you have a charger that will charge LiFe packs. Not LiPo but LiFe it is a different . Lipo's 2S charges at 8.4 volt and a LiFe is charged at 7.20 volt. These are not the actually voltage just the charge voltage. Once it is off the charger a LiFe will settle down to 6.66 - 6.68 volt
If you have the compatible charger already then just get a LiFe pack. They weight a lot less than what a comparible NiMh is and the LiFe will supply a full 6+ volt for it's entire safe discharge even under load.
They are cheap. My LiFe 1300 packs only cost $17 each.
Old 05-18-2014, 04:51 AM
zen3
zen3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have to check. I do believe my Hyperion 1210i can charge life. Then I'll get back to you about the pack.
zen3 is offline
Contact Us Archive Advertising Cookie Policy
