Huge Aeromarine 4ft Rc Shovel nose Hydroplane What scale
Hi I just got this hydro it has not been run for 2 years but it was used in a few races. I cant find anything like it online except for a smaller one from aeromarine. Some info on the boat Below What scale is it I put it on ebay as I need to sell it
THIS VINTAGE STYLE HYDRO IS LARGER THAN THE 1/8 SCALE SO I THINK ITS A 1/6 SCALE NOT SURE. MEASURES 51" TO END OF PROP SHAFT AND HULL IS 48" LONG BY 24" WIDE MARKED INSIDE HULL AEROMARINE LAMINATES 2002 AND THE MOTOR IS MARKED ZENOAH I DONT THINK ITS STOCK AND IT AT LEAST A 260 AS THIS BOAT WAS USED IN COMPETION. THE BOAT IS IN EXCELLENT CONDITION AND WAS USED IN A FEW RACES BUT HAS NOT BEEN RUN FOR 2 YEARS. THE STRING PULLS AND GREAT COMPRESSION ALSO COMES Futaba 3-Channel 3PMX Computer Radio with the 2.4GHz FASST System Transmitter and R603FF in working order with charger. The carb is marked walbro and the only number I can see is 310 on the throttle arm on carb.WAS RUNNING PERFECT WHEN LAST RUN.
THE ONLY DAMAGE I SEE IS ON THE COWLING AS SHOWN IN PHOTOS.
It is a Aeromarine Shovel nose hydro
Same one was for sale here just the other day.
http://www.rcuniverse.com/market/item.cfm?itemId=928255
