Could a Gas boar motor be used for a Drag Racing motor??
One of the differences i have noticed between a onroad gas motor compared to a boat gas motor the boat motor does not have a fan type flywheel. I suspect that the fan type flywheel causes drag on the motor that increases with rpm. I think that a boat motor can turn higher rpms than the same size onroad motor because it does not have a fan type flywheel. So my question is do any of you rc boat motor guru think I could get away with using a boat motor for a drag motor ??
Duh!! I know that. So do you think I could get away with using a boat motor?? Just like the motors in real dragsters don't have a fan I figured I could do the same thing with our gas motors because they won't be ran for very long, a drag race is usually over in a few second. Motor on motor off.
try lowering your rotational mass of the drivetrain if you want rpm ........... duh
Tough to call but I imagine it is possible as long as you did not stage it for long (at all) and allowed a full cool down between races (could even flow some water through it when in the pits after the race). I have seen plenty of boats started and run for longer than I would feel comfortable at revs higher than I would pick before launch or when tuning - and then there are those times a boat runs ashore and revs an unbearable song - so they can do it and survive (sometimes).. Another option might be to fill the head with water before the race and seal with a silicon hose that will blow off with pressure - though dangers from steam scalding. Might afford the motor a little extra run time though. Full size drag racers dont get many races out of a motor - this may be the case with using a water cooled motor without cooling too though.
a lot ofArabs use not active cooled engines for their dune drag racing cars (outsidetemps around 40°C = 104°F) but they use alcohol instead of gas.
They firethe engine, let it run a few seconds and then the car runs up a dune hill anddownwards. Or they are running at sand beaches.
Alcohol(methanol) has a self cooling effect that means, that this medium will cool theengine due to evaporation cooling.
We haveprepared a few engines for that purpose w/o active cooling, we took air cooledcylinders but w/o fans.
I have seenin the web that a few US modelers took boat motors, put aircooled top ends onthose and were
runningwith success. But I do not know whether alcohol or gas.
If you’duse boat cooling cylinders and put water into the cooling heads, the water willbecome steam and will be blown out, this will work also,
the headswill stay at 100°C (=212°F) until the water / steam is blown out.
But: if youdo not use distillated water the inside of the cooling area will be filled withthe remaining particles of the water, for example chalk / limescale and thiswill lead to a worse cooling efficiency
.....................No you think you know all the answers read my post all the way thru THE MOTOR IS NOT GOING TO BE RAN A LONG TIME.
IN
when I was a wrench on a double A gasser we had a hose we connected from a water faucet to the block, make the run and after the run go to the pits reconnect the hose and open petcock and cool the engine down and refill with water for the next run
ON, CANADA
I'm no rocket scientist by a long shot but why not just buy the flywheel and keep the finned cylinder for cooling? Seems like the obvious simple cheap solution to me..... who knows may or may not even do anything. Certainly a cheaper way to find out than buying and potentially cooking a marine engine.
.......................thanks for the tip radioman.
ON, CANADA
Ya they are available many places after market and different weights, could get a lighter one that would also spin up quicker. Cost anywhere from 25$ up.
I'm a boater who just stumbled across this thread, I admit I don't know much of anything about cars, may be a simple reason it won't work in a car, but if you figure a boat engine would work can't see why just the flywheel wouldn't work on your car engine.
IN
all boat motors have a flywheel some older motors where air cooled most modern motors or water cooled so a flywheel with a cooling fan wont cool the engine enough the block and heads have water jackets in them the cylinders will get hotter without the water in them
most of the time a boat motor, has a cowl covering it so it gets no air flow over the cylinder head which is why you have water jackets. But in a dragster the motor would be sitting out in the open getting lots of air flow when the car gets going. So long as I don't idle too long or do alot of burn outs the motor should not over heat.
Looks to me to be more than a 'quick' run - guys run them here as well ---------
If you run alcohol you may get it to run long enough -- or a marine case with finned Air cooled cylinder - most marine engines 'spool up' better than air cooled because we run less rotating mass (no clutch - gears - u joints - big tires etc.
http://youtu.be/wNIjLU3diYI
Buy a WidowMaker and save yourself the grief
http://youtu.be/IC_QIHZ01MI
A friend was a brag boat racer and had a bored out Mercury 400 engine in it running top gas and then alcohol. He had is water jacket filled with something (I think aluminum but may have been some type of sand) to dissipate the heat. AFAIK they do not run those engines dry.
