Active Spark Timing
Active Spark Timing
Howdy Everyone,
Disclaimer: This is more of a knowledge share question, see if anyone has done it or thought about it.
Has anyone ever tried active spark timing while the engine is running? Whether it be electronic ignition or other?(My idea was to attach the coil of the saw engine onto something that could rotate around the flywheel controlled by a servo from a redboard. The redboard would have a O2 sensor and know throttle position and crank rpm in order to calculate adjustment for timing.) I realize there is little to gain here for all the work and don't think i'll end up even trying it, however, the idea sounds fun and sparks my engineering "creativity". Let me know what y'all think. (Besides "It's the dumbest idea that will gain you little to no power", i already know this)
Brandon
Brandon
You can buy electronic programmable ignitions already (w/o O2 sensor - we run too much oil for many O2 sensors to work properly)
http://www.matho-powertrain.de/index_en.html
pick 'web catalog' on left of screen
