Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
New Hydro design and build
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 03-16-2018, 04:16 AM
F1madness
F1madness's Avatar
Default New Hydro design and build
Been wanting to design and build 1 of these for a while now and after few small sketches i decided was time to do full size drawing i wanted it to be
i wanted to get the exhaust inside the hull to keep it sleek lines and looks not the easiest but with some certain regulations over here in our club i wanted to be able to race it and bring something new to the water
Once happy with drawings i started the build LOL
everything you see is done by hand and once started piecing it together hence the LOL above i started changing couple of lines till i was satisfied
Hope you like and enjoy the pics
Old 03-16-2018, 04:18 AM
F1madness
F1madness's Avatar
Old 03-16-2018, 04:20 AM
F1madness
F1madness's Avatar
Old 03-16-2018, 04:22 AM
F1madness
F1madness's Avatar
Old 03-16-2018, 04:24 AM
F1madness
F1madness's Avatar
Old 03-16-2018, 04:31 AM
F1madness
F1madness's Avatar
This was just an idea hmmm
Old 03-16-2018, 04:33 AM
F1madness
F1madness's Avatar
this is where im at now
will post more pics of progress
Old 03-16-2018, 05:25 AM
F1madness
F1madness's Avatar
Starting to take shape now
Old 03-16-2018, 01:16 PM
crapshooter
Very well done. looks great and can imagine how nice the hull will look when completed., lots of cutting hey.
Old 03-17-2018, 02:09 AM
F1madness
F1madness's Avatar
Cheers bud
the loads of cutting didn't help kept changing lines here and there lol
should look good when done which I'm looking forward to seeing the build finished
Old 03-18-2018, 03:57 PM
crapshooter
Last pic i notice the sponson ride pad set up looks different to the average sport hydro where the ride pad is lower than the outer but on yours the ride pad meets the side outer skin which extends abit lower than the main ride pad. does this make sence to you ?
Old 03-18-2018, 09:50 PM
F1madness
F1madness's Avatar
iv designed it with so the ride is at an angle/deadrise not flat 90* then a 2nd then the outer part of ride pad sits just over it creating a negative strake
I run the same design on my F1 with great results
Old 03-19-2018, 02:25 AM
F1madness
F1madness's Avatar
Made more progress
topdeck skins are done still needs final sanding but will do that in 1 hit once complete
Prepped and added skin to sponson top had to use few more tacks than would of liked but wont be an issue
Old 03-19-2018, 10:01 AM
F1madness
F1madness's Avatar
Old 03-20-2018, 01:15 AM
F1madness
F1madness's Avatar
Still not 100% sure on the fin hmmm??
Old 03-20-2018, 07:40 AM
F1madness
F1madness's Avatar
This thing needs a name LOL
1210mm x 590mm (47.5" x 23 1/4") overall size
Main work on hull is done couple little bits to do but only cosmetic will do full shaping and finishing off in 1 go next is the hatch hmmm this should be fun hahaha
Old 03-20-2018, 01:34 PM
crapshooter
Looks very nice indeed, are you going to have the pipe inside the tub ?
Old 03-20-2018, 10:42 PM
F1madness
F1madness's Avatar
hi bud
yes mate designed it to have pipe inside tub to comply with the rules of our club plus keeps it looking sleeker and 1ltr fuel bag upfront so got enough fuel to last the 20-30 minute race heats
Old 03-21-2018, 01:39 AM
crapshooter
That will look neat having the pipe hidden in hull. you guys do have long races .
Old 03-21-2018, 10:21 AM
F1madness
F1madness's Avatar
yeh i wanted to keep the sleek looks but comply with the rules cant have anymore than 65mm exposed exhaust so made sense to just hide it completely not the easiest to achieve and have sleek looks but think iv managed it LOL
Old 03-25-2018, 01:36 AM
F1madness
F1madness's Avatar
Starting on the hatch , cutting the ribs now that im happy with the radius
only rough cut for now will trim and sand in pairs so they match both sides
these will be spaced apart then some high density foam cut and inserted between them and shaped
Old 03-25-2018, 10:22 PM
crapshooter
what thickness are those ribs ? keep it light.
Old 03-26-2018, 12:42 AM
F1madness
F1madness's Avatar
spine and ribs 6mm ply
wont matter about weight as ill be molding it so this is just a plug
Old 03-26-2018, 11:53 PM
crapshooter
seems a shame to spend so much time on a nice wooden hydro only to use it as a glass plug hey.
Old 03-30-2018, 05:27 PM
Ron Olson
Ron Olson's Avatar
Daz, it's normal rules on this side of the Big Pond in the Thunderboat classes. It might be a tight fit at the transom but it's doable. I also run the exhaust through transom of my Jersey Skiff. I get my parts through Zippkits but if you have a TFL Hobby dealer there it's the same pieces. You just need a LOT of air moving through the hull. You might have run across that with your IB tunnel hulls.
