My Craigslist Find/Rudder Question
I had been wanting to get back into gas RC boats, but had not wanted to shell out big bucks yet. I ran across an ad on craigslist for a 48" gas powered RC boat for $50! I thought it was a typo and contacted the guy. Sure enough it was $50 with radio and running engine! The engine appears to be an air cooled Homelite with a clutch. The guy said that he built the boat himself from an old weedeater. He used an old Traxxas radio and still used the gas tank from the weedeater, so it wouldn't sit down in the hull. The only thing it needs is a rudder which I'm having an issue with. Does anyone recognize the running gear I have on the back of this boat and what rudder will work with it? All I know right now is that it looks like it needs a wedge rudder but I have no clue what size. Also, can anyone ID the hull? He didn't know what the make was. Thanks!
Eric
Eric
My Feedback: (51)
The hull is a Radio Active Equalizer and the hardware is an Octura brand, The rudder you need is the WRBOLL with a 6 3/8" blade and you'll need another tiller arm which is the black thing that holds the rudder onto the bracket.I always buy two in case one breaks. Call Octura and order your stuff at 847-674-7351 They don't have a website.That bent wire rudder setup isn't very good. Move things around in the radio box to have the rudder control come out on the right side of the rudder and straight,no bends.You can get regular fuel tanks or an IV bag that will fit on the carb side of the rail.
Thanks for the info! I will move some stuff around in the radio box to get a straight shot at the rudder. Thanks for the info! Are the tiller arms universal or is there one specific to my rudder? Thanks again!
No, mine did not come with a hatch cover however the previous owner did say that it came with one originally when he bought it.
Just wanted to share something about rudder pickups. Our boats naturally want to turn right so to go straight the left side of the rudder is the working side. You want the pickup on the left or the working side otherwise the engine can get starved in the straights and only get proper flow while cornering to the right.
I realize you think we make right turns so the left side would starve it in the turns and it does slow the flow in the turns no doubt but a high performance engine is going to want best flow while in the straights so the left side is where the pickup works best by a long shot.
Never buy one with both right and left feeding one fitting. The side with the most pressure overcomes the other and most of the volume goes out the other side and never builds any pressure/flow.
Thanks for the info! The rudder got here today and everything fits perfectly! Unfortunately I can't run it today but I will soon! I got the one with the pick up and I'm going to leave it uncapped to see the difference in flow like you were saying. Can't wait to get this beast on the water!
Another question, I want to get a fuel tank that goes down in the hull. I'm just looking for a traditional hard tank and not an IV at the moment. Are there any that are ready to go? Something with a pickup already in the tank so I can just hook my fuel and return lines up? Also what do yall's fuel filling setups look like? I'm guessing most use a hand pump. Do yall drill into a regular gas can and put a fitting in to run hose inside of it? TYhis is my first time to have a running gas boat and have never got this far before. lol Thank for all the help so far!!
