Speed - RC Gas Boats Discuss gas RC boats right here!
Water pump for gas boat
Reply
Old 12-28-2018, 05:30 AM
vuuli312
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Water pump for gas boat
Hi.I was wondering if someone could post some pictures of the inside of the water pumps used to cool gas engines. Id like to see if its possible to make one .I know they operate from engine vacuum using a diaphragm.Thanks to all.Im converting a 4 cycle trimmer to marine use and need a water pump to circulate water to the water cooled head.One other question, does a 4 stroke create enough vacuum to run these pumps since these pumps typically are used on 2 strokes.thx
vuuli312 is offline
Old 12-29-2018, 02:42 AM
Tidnab
My Feedback: (51)
Tidnab's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's some info from the Walbro site. FPC-pump-8-20-12.pdf
Tidnab is offline
Old 12-29-2018, 06:44 PM
quickdraw
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Unless you will be sitting idling with a clutch? You do not really need a pump. Even if you had a clutch you do not really need one unless sitting and not moving for a bit.
quickdraw is offline
Old 01-02-2019, 06:19 AM
Justaddwata
Justaddwata's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As mentioned above - the requirement of a water pump is not critical as long as the boat is not left idling for too long - movement of the boat (or the thrust from the prop - depending on your setup) should flow sufficient water at modest speeds.
The pulse pumps we use are actually used as fuel pumps on larger 2 strokes like jet skis etc. https://www.ebay.com/sch/i.html?_fro...lbro+fuel+pump
That said - I am not sure a pulse type pump would work well with a 4 stroke as I don't believe you will see the same pressure pulse in the crankcase as the 2 strokes do. A belt driven pump like used on the Blata 40 motors might be one option - another option might be to use an electric pump (like a windshield washer motor or similar). You may also adapt an aquarium or fountain pump to suit your needs - https://www.ebay.com/itm/Ultra-Quiet...-/392158991138
Justaddwata is offline
