RCMK K30 motor
RCMK K30 motor
I need help.
I have a pair of RCMK K30s and they are counter rotating pairs.
How do I visually tell which is rotates clockwise or counter clockwise without starting them ?
Thanks in advance
Thanks in advance
Check where the primary coil is. I only had the 26 cc RE RCMK. The problem with the 26 cc was that they made several version of the RE engine. I don't know if RC Marine Korea will be any help or not.
One should have a R printed on face of flywheel. The right hand counter rotator RZ style usually has left hand threads for collet and on flywheel. Try threading a 6mm bolt in crank. The one it fits it the normal left hand one.
Are they R engine or RZ.
The R of course is different the collet bolts in the flywheel and flywheel is in back. The coil location being right or left for R or RZ will tell you to.
Go on RCMK Korea you can see pics of them all.
