Motor ID
FL
RE: Motor ID
the first boat looks like a homelite, the other is a fuji. the g23 will smoke a homie. zenoahs are built alot differently than the homies, they are more perfomance oriented.
FL
RE: Motor ID
hmm....after you said that and i looked at the starter location i agree with you its not a homie. that shroud is a weedeater type shroud and homie does not make a weedeater with starter on that side. only their chainsaws have it on that side. if its the same motor as the one on the right i'm betting its a fuji. if its one of those bat boats that come prebuilt its almost definetly a fuji. a g23 will still smoke it.
